| RS125_Tecky |
 RS125_Tecky Trackday Trickster
 Posted: 21:35 - 04 May 2005 Post subject: Pistons! Help!!!!! |
I know i already posted a topic on this but this is a different Q.
I was on my RS 125 after a recent new piston kit had been fitted, when it started loosing power (going really slow in all gears) then within about 2 minutes is cut out.
It didnt cut out INSTANTlY it sounded like a bike sounds when it runs out of petrol where it gradually cuts out.
What im trying to say is, if the piston came of the conrod wouldnt the bike of cut out straight away, instantly.
But as it gradually died out could this mean ive only NIPPPED A PISTON RING.
Kickstart you will prob know
Cheers |
| R4nger |
 R4nger World Chat Champion
 Posted: 21:37 - 04 May 2005 Post subject: |
Sounds like a serious engine problem like when I seized my instructor's bike.  |
| Kickstart |
 Kickstart The Oracle
| RS125_Tecky |
| Kickstart |
 Posted: 21:50 - 04 May 2005 Post subject: |
It could have nipped up, but hopefully not (as that would trash the piston and might trash the barrel), but doing it slowly would tend to happen from overheating and that does not seem to have happened from what you say.
Personally I would start looking through the fuel system. Open the fuel tank and check it you hear air rushing in (ie, blocked breather hose). Check for kinked fuel hoses. Clean out the fuel filter. Check nobody has turned the fuel off on you. Drain the tank just in case there is water in there (this would probably be most likely if the problem happened just after going onto reserve).
| pipnet11 |
 pipnet11 Brolly Dolly
| Frost |
 Frost World Chat Champion
| RS125_Tecky |
| binge |
 binge Emo Kiddy
The last post was made 21 years, 133 days ago. Instead of replying here, would creating a new thread be more useful? |
