removing honda brake calipers/pads
gimpy limp
PostPosted: 14:56 - 07 May 2005    Post subject: removing honda brake calipers/pads Reply with quote
Am I being thick, theirs 2 bolts which attach the caliper to the frame then theirs another 2 bolts which on mine are veeeeeeeeery very stiff, I can't loosen it even a little bit. The pads are touching and I need to loosen thm to get it over the brake disc and bolt it onto the frame. What do I do to loosen it?
pics:
https://img161.echo.cx/img161/1654/cx500enginein30016mi.jpg
https://img108.echo.cx/img108/2289/cx500enginein30036nu.jpg
-=[Sam/b]=- cx500's the only way to travel, we do it in style just like jimmy saville
msn addy - [email protected]
https://pre-auto.com/cx500/rat_and_survival_gallery_2006
Jammy-G This post is not being displayed because the poster is banned. Unhide this post / all posts.
gimpy limp
PostPosted: 15:03 - 07 May 2005    Post subject: Reply with quote
is it definatelly these bolts here:
https://img228.echo.cx/img228/489/30tw.jpg
they were off when I bought the bike, seemed abit dodgy to me that they are so stiff didn't want to put my whole force into them if it's the wrong thing.
gimpy limp
PostPosted: 15:05 - 07 May 2005    Post subject: Reply with quote
https://img179.echo.cx/img179/6703/calip5hq.jpg
ZRX61
Victor Meldrew
PostPosted: 15:28 - 07 May 2005    Post subject: Reply with quote
Those bolts hold the two halves of the caliper together, if all you're trying to do is seperate the pads just pry em apart with something.
Do NOT loosen those two bolts to seperate the pads....
gimpy limp
PostPosted: 15:39 - 07 May 2005    Post subject: Reply with quote
just gave that a go and it's not having none of it, sperate like a mm or 2 but thats it
Mr C
PostPosted: 15:53 - 07 May 2005    Post subject: Reply with quote
take the lid off the master cylinder and wrap a cloth around it then try prying the pads apart
the fluid needs somewhere to go
187.3bhp = 201mph
WildGoose
White Van Man
PostPosted: 15:58 - 07 May 2005    Post subject: Reply with quote
wouldnt jam a screwdriver between brand new pads personally, can you not take the pads back out, then try and push the pistons back?
ZRX61
Victor Meldrew
PostPosted: 16:03 - 07 May 2005    Post subject: Reply with quote
Nor would I, he needs to get a couple of metal scrapers in there & then get a pry bar between those, couple of putty knives may work.. or raid the kitchen for a couple of knives...
westendboy7
PostPosted: 16:55 - 07 May 2005    Post subject: Reply with quote
Perhaps you should relieve the brake fluid pressure then the pistons will slide back if they are not siezed
Villers
PostPosted: 16:59 - 07 May 2005    Post subject: Reply with quote
Remove new pads, insert old pads, use a spanner or such like to lever the pistons back protecting them with the old pads. Once nicely separated remove old pads and put new ones back in, slide over disc happily and secure to bike!
Had the same problem on my CBR6 with rear pads, nice of honda to put the exhaust right over the caliper too!
gimpy limp
PostPosted: 17:34 - 07 May 2005    Post subject: Reply with quote
ahha all done, needed abit of a gentle pursuation with the right chisel/screwdriver is all (use a wide one and your sorted) cheers Twisted Evil
The last post was made 21 years, 145 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.47 - MySQL Queries: 13 - Page Size: 72.79 Kb
