snapped clutch lever bracket thingy
gimpy limp
PostPosted: 15:20 - 07 May 2005    Post subject: snapped clutch lever bracket thingy Reply with quote
it's only a small part that holds the outer clutch cable still. How can I fix this? i've got no idea how I can replace this, honda dealership somewhere maybe?
Those universal clutch and throttle levers on eBay are meant to be really horrible to use and flimsy so I don't want to try one of those.
Here's a pic (easier to explain):
it's that bit underneath where i've circled that holds the cable on
https://img50.echo.cx/img50/5138/clutchcable1rh.jpg
1980 cx500 it is
-=[Sam/b]=- cx500's the only way to travel, we do it in style just like jimmy saville
msn addy - [email protected]
https://pre-auto.com/cx500/rat_and_survival_gallery_2006
WildGoose
White Van Man
PostPosted: 16:03 - 07 May 2005    Post subject: Reply with quote
cant really see what you are looking point out
broken lever?
new lever https://shop.wemoto.com/pictures/hl/81a96.jpg
not sure exactly what model cx500 it is, but wemoto have the spares for them all
gimpy limp
PostPosted: 16:30 - 07 May 2005    Post subject: Reply with quote
the lever part in that picture you posted is actually fine as far as I can tell. The clutch cable unless the outer is held still while you pull on the lever and the inside cable moves it's not going to work. that's all it does, it holds onto the outer shielding of the clutch cable - the small bit I've circled
westendboy7
PostPosted: 16:51 - 07 May 2005    Post subject: Reply with quote
Looks like the part that the cable sleeve slides into not the lever. If that's what it is then you'll need to replace. Most motorbike shops should be able to order the part for you.
The last post was made 21 years, 143 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.7 - MySQL Queries: 13 - Page Size: 40.75 Kb
