dummmmmmmb carb/chokes question
gimpy limp
PostPosted: 16:35 - 09 May 2005    Post subject: dummmmmmmb carb/chokes question Reply with quote
i know it's probably a dumb question but are the chokes when their is no pressure on the throttle supposed to be open all the way?
with mine when theirs no pressure on the throttle they look like this (only open a couple cm's):
https://img24.echo.cx/img24/8687/cx500carbs13pq.jpg
when the throttle is on all the way they close fully like this:
https://img24.echo.cx/img24/5880/cx500carbs28fl.jpg
i'm sure it should be the other way around, because surely it's stopping air coming in if they close up when you pull the throttle down?
but are they meant to be open this much or has the bloke who took this photo disconnected the throttle cable for them to fully open (with the cable off mine it opens this much):
https://www.elsham.pwp.blueyonder.co.uk/cx500/carbs_balance/carbs29.jpg
-=[Sam/b]=- cx500's the only way to travel, we do it in style just like jimmy saville
msn addy - [email protected]
https://pre-auto.com/cx500/rat_and_survival_gallery_2006
Gazdaman
I did a trackday!!!
PostPosted: 16:38 - 09 May 2005    Post subject: Reply with quote
With the throttle fully open your carb slides should let air through. i.e should move completely out of the way.
looks like you've messed something up.
Does it run? is this something you've just done?
Need more background info.
Gaz
feef
Energiser Bunny
PostPosted: 16:40 - 09 May 2005    Post subject: Reply with quote
the choke butterfly valve is not attached to the throttle.. only the choke lever moves the choke valves Wink
with the choke off,m they should be pretty much fully open tho...
a
Mudskipper wrote: feef, that is such a beautiful post that it gave me a lady tingle Laughing
Windchill calculator - London Bike parking
Blog and stuff - PlentyMoreFish dating
gimpy limp
PostPosted: 16:44 - 09 May 2005    Post subject: Reply with quote
I think i must have connected the throttle cable to the choke part of the carbs. I haven't connected the choke cable yet. lol i'll have another look, numpty
i'm getting a key cut today so was hoping to start it tomorrow. Everything else is wired in just when I had anotherl ook at what i've done their it didn't seem right (good job I checked before I start it).
bish777
PostPosted: 16:45 - 09 May 2005    Post subject: Reply with quote
if you look at the top there is an opening-this bypasses the main butterfly and feeds air to the engine and the pilot jets at idling speeds.
The choke opens a valve usually that allows more air and fuel in to the engine, thus aiding cold starting.
GSXR1100J
feef
Energiser Bunny
PostPosted: 16:46 - 09 May 2005    Post subject: Reply with quote
the choke, when fully "open" actually closes the valve, as this makes it richer, and hence easier to start...
bish777
PostPosted: 17:08 - 09 May 2005    Post subject: Reply with quote
youll find this will vary from carb design to the next. What i described was the action of my Mikuni CV34's and most other CV carbs and flatslides are similar.
GSXR1100J
gimpy limp
PostPosted: 17:14 - 09 May 2005    Post subject: Reply with quote
ahha sorted it, that'll teach me to rush things. yeh the throttle was on the choke, swapped umm round now and it's fine.
The last post was made 21 years, 149 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 59.37 Kb
