my 2 day old bike gone and bust on me :(
danclarkie
PostPosted: 23:07 - 11 May 2005    Post subject: my 2 day old bike gone and bust on me :( Reply with quote
my bike i had for only 2 days now (not technically 2 days old but an 03 reg just over 1 n half years old) rising along today happy as larry Laughing the bike just looses power and starts dying so i hit the clutch n coasted to the side of the road. i thought "bloody hell i only put petrol in this morning and its on reserve already" Shocked but alas no not even switching to reserve could sort it, opened the tank and it was almost full. so there i am miles from home busted bike phone with no credit sat on my arse at side of the road thinking what to do. i fiddle around for about half an hour not knowing what to do and nothing comes of it, about 20 bikes past me none stopped to see if i was ok Sad then after about an hour my girlfriend rings me so i finally get to speak to someone, anyone some faffing later i get the bike home.
tried bump starting it and nothing, backfired a bit and spluttered but nothing.
took the spark out and it all sparks fine, checked the fuel lines and thier all good, the air filters working perfectly and the carb is getting air and fuel. the engine is in good condition and is maintaining compression inside which you can see by turning engine over with thumb over spark plug gap. all the parts seem to be working perfectly individually even the valves and timing chain i checked, been spraying quick start into the air filter at first then into the carb and finally into the engine itself and still will not start, please anyone got any ideas at all. im really totally out of any clue what it is all fuses are good everything the battery has been fully charged.
help!!!
Bah Humbug
TOM M
PostPosted: 23:13 - 11 May 2005    Post subject: Reply with quote
checked that ya engine kill switch isnt pressed in??
Now owner of a 1200 Bandit
danclarkie
PostPosted: 23:25 - 11 May 2005    Post subject: Reply with quote
just been to check that, cant belive i didnt think of that Embarassed but no its not the kill switch Sad
Bah Humbug
PostPosted: 02:46 - 12 May 2005    Post subject: Reply with quote
Try a new plug in it anyway, they can spark outside the engine but not inside it.
Is the plug wet after you have been turning it over for a bit? because it should be.
Sidestand idiot switch living up to its reputation as the root of all evil?
If you are broken down at the side of the road again and could use some help, make sure you put your helmet behind the back wheel to signal this to other riders. They might have assumed you were just taking a break, especially if you were trying to speak on your mobile.
danclarkie
PostPosted: 03:00 - 12 May 2005    Post subject: Reply with quote
the plug is wet and slightly black around the tip, the plug im sure is as old as the bike so over 1 n half years, seems its highly likey its not sparking inside the engine and me and my mate couldnt understand why if it was sparking outside the engine, why would it suddenly stop working though?? Confused when i was riding along and the engine was warm
Bah Humbug
PostPosted: 03:15 - 12 May 2005    Post subject: Reply with quote
There is a difference between a spark, and a good spark. A good spark will be fat and blue and arc directly down from the electrode to the tang of the plug. A knackered plug can still spark but the spark may be weak, intermittant or arcing to the edge of the tang or even the rim of the plug. A bad spark can disappear when you subject it to high pressures in a hydrophobic vapour laden atmosphere (like inside an engine)
For the 2.50 it would cost it is worth a try.
danclarkie
PostPosted: 03:18 - 12 May 2005    Post subject: Reply with quote
tres bein!
ill have to look at that first thing tommorow il let you know how it goes, if its not that or the float bowl, im putting my mum forward for acts of witchcraft, every other possible option has been exploited. Crying or Very sad
Bah Humbug
NSR125-Kid-UK
Attention Whore
PostPosted: 05:24 - 12 May 2005    Post subject: Reply with quote
Eh? What spark plugs do you use SW? Laughing
Mine are £7.50 Laughing
https://www.bikepics.com/members/nsrandy/96rs250/ My Bike!
"I'm either going to teach andy to get his knee down, or I'm going to get him killed. One of the two" - Teaman
Suzuki
Roger
PostPosted: 11:47 - 12 May 2005    Post subject: Reply with quote
I didn't know that. Is this common knowledge?
Thanks though Thumbs Up
<Simple> no I'm shaven Jon Razz
<Simple> it is a big enough hole.. I'll leave it now
Ride: 1999 Suzuki GSXR600 (yellow/black) IRC: Stats - Relationship Map
c058y
PostPosted: 12:15 - 12 May 2005    Post subject: Reply with quote
I didnt know about the helmet behind the back wheel either! I've stored that in the memory bank! Thumbs Up
paulthewitt
PostPosted: 13:52 - 12 May 2005    Post subject: Reply with quote
its either the helmet, or alternatively the seat rested against the back wheel.
waving frantically sometimes works too!
Paul
biggerjohn
PostPosted: 14:33 - 12 May 2005    Post subject: Reply with quote
Paul
noted for future use
thank you
PostPosted: 14:34 - 12 May 2005    Post subject: Reply with quote
NGK B8HS for my 2-strokes. £2.50 to £3 each. I go through a lot although recently I bought six plugs, four of which were duff. I prefer Nippon Denso plugs but there is noone round here that sells them.
Zoffo
PostPosted: 17:33 - 12 May 2005    Post subject: Reply with quote
Paul
Having a pair of tits works even better
https://hyperbikes.forumsplace.com/
The last post was made 21 years, 120 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.15 - MySQL Queries: 13 - Page Size: 85.37 Kb
