What do I do with the damn XJ?
Gazdaman
I did a trackday!!!
PostPosted: 20:28 - 11 May 2005    Post subject: What do I do with the damn XJ? Reply with quote
Well, when I crashed the other day I bent the right handlebar severly, broke the throttle/mirror.
Now turns out the forks are twisted, hopefully just inside the yokes though.
Some options open to me are:
Repair back to normal albeit with a black top fairing rat style.
Put some clip-ons on it, streetfighter headlight, no fairing. Ugly as hell.
Break it and sell for parts, with a 72k km engine, not worth much, fairings knackered, not worth fuck all.
Any tips on getting it back on the road cheaply much appreciated. If I could just put some renthals on it I would, but it uses silly 2 piece bars.
Gaz
instigator
PostPosted: 20:32 - 11 May 2005    Post subject: Reply with quote
Just put some new forks on (from a breakers) and hey presto...better and cheaper. Breaking it would only mean more bother.
Can't you just nab some clipons from other bikes or are they of a specific diameter on the fixings Confused
White Noise
Mr Dudwee
PostPosted: 20:33 - 11 May 2005    Post subject: Reply with quote
Have you searched around for second hand forks?
if you can get them cheap, repair the bike cheaply and use it like you don't mind dropping it
or is that how you ride it at the minute? Razz
WN
Gazdaman
I did a trackday!!!
PostPosted: 20:38 - 11 May 2005    Post subject: Reply with quote
I think the forks would be fine if I just loosen off the yokes and put them back in true.
The handlebars are specific, and I got quoted £39 for the right bar, and the throttle inc postage.
But on a £425 bike with an engine that's on its way out I'm not sure if it's worth the effort.
Gaz
bish777
PostPosted: 20:43 - 11 May 2005    Post subject: Reply with quote
depends how bent the forks are? Loosen off the clamps, and striaghten the wheel out, see how it goes. My XJ600s were bent i just twisted the stanchions so they were bent in the same direction.
as for the fairing, rat it!
GSXR1100J
Gazdaman
I did a trackday!!!
PostPosted: 20:46 - 11 May 2005    Post subject: Reply with quote
I think it probably makes most sense to put it back to standard.
Spray the fairing black, new handlebar, then ride it until I kill it.
Then scrap heap it. Cuz it sure isn't worth anything!
Gaz
PostPosted: 20:49 - 11 May 2005    Post subject: Reply with quote
Exhibit A.
Kawasaki gpz500s bodgefighter. Total parts cost 80 quid for fancy bar clamps to replace silly 2-piece handlebars, alloy drag bars, headlamp fairing and new grips. All delivered in 24h from Busters.
Total fitting time 45 minutes using existing front subframe. Very Happy
White Noise
Mr Dudwee
PostPosted: 20:51 - 11 May 2005    Post subject: Reply with quote
LMAO, class directions Stinkwheel!
WN
Gazdaman
I did a trackday!!!
PostPosted: 20:55 - 11 May 2005    Post subject: Reply with quote
now those bar clamps I do like!
Any more info on those?
Gaz
PostPosted: 21:01 - 11 May 2005    Post subject: Reply with quote
You have to specify the fork diameter, they just clamp on round the fork stanchion. You need at least 25mm of exposed stanchion to get a good hold. Choice of high or low rise (low rise in my piccy).
https://www.busters-accessories.co.uk/proddetail.asp?prod=RAA
Gazdaman
I did a trackday!!!
PostPosted: 21:09 - 11 May 2005    Post subject: Reply with quote
£35 each?
Christ, that's an excellent idea, that'd be really usefull, that's another option boys and girls!
Gaz
Josh|RD125LC
PostPosted: 21:32 - 11 May 2005    Post subject: Reply with quote
Maybe you should now be looking into putting alot more time into your TZR?!? Get that beast on the road and looking sweet, you'll be saying "what XJ?" Smile
Honda MBX50 | Yamaha RD125LC | Suzuki RG125F Lucky Strike | Suzuki GSF600S
RD125LC Pictures
epz
PostPosted: 01:23 - 12 May 2005    Post subject: Reply with quote
Gaz
my advice would be strip it for useful parts and dump it, the frame could be damaged and odds are its on its way out anyway, you might get some cash for various bits on ebay.
its not like the divvy is a good bike or anything, i would treat it as an oppertunity to upgrade to a bandit or trx
PostPosted: 11:15 - 12 May 2005    Post subject: Reply with quote
At £40 for a new bar and the throttle bits, just replace them. By the looks of the fairing I would just leave that well alone and not even paint it (likely to look even worse painted matt black), maybe at most using a bit of glass fibre and resin to hold any broken bits together.
If you start playing with different bars then you open up the possibility for having to replace hoses cables for longer ones, having switchgear which no moves around the bar, etc. All things that can be fixed, but not reallly worth the hassle if you just want to sort it out cheaply.
Chances are that the forks are just twisted in the yokes. I would rather hope it would take more than that to bend them.
Gazdaman
I did a trackday!!!
PostPosted: 15:23 - 12 May 2005    Post subject: Reply with quote
Well, I am going to put it back to standard, but the top fairing is being sprayed. I'm not too bothered about looks, but I can't stand such deep scuffs everywhere, it looks awfull. I'd rather have a rat-black fairing than a standard but f*cked one.
Thanks for the advice guys, I may even put some XJ900 bars on which are adjustable Thumbs Up.
Gaz
PostPosted: 15:27 - 12 May 2005    Post subject: Reply with quote
Think very carefully, as do you really want to spend money on making it look more obvious that the fairing is knackered?
Gazdaman
I did a trackday!!!
PostPosted: 16:04 - 12 May 2005    Post subject: Reply with quote
(I've already started taking the stickers off)
I would post the damage, but it's EXTREMELY obvious it's damaged.
If I were to attempt to sell it, I doubt it'd sell for any more than £150, the bike is knackered, so I figure I may as well ride around with a black fairing than a very very scuffed (on both sides) red one.
I've found a whole albeit non runner of an XJ600 near me, I may buy the whole thing, and put all the plastics of that on mine, (dented my tank aswell).
Or I may just ride that!
Gaz
PostPosted: 16:07 - 12 May 2005    Post subject: Reply with quote
Depending on the condition that could well be worthwhile. Make one good runner from the pair and have loads of parts left over.
Gazdaman
I did a trackday!!!
PostPosted: 16:10 - 12 May 2005    Post subject: Reply with quote
All depends how much he wants, my engine is very much on the way out as it is. If I can pick it up for <=£100 then I'll do it.
If I can put his engine in it, assuming it's done fewer than 72k Rolling Eyes I can scavenge the other bits it needs, only bad thing about it, it has a bent frame, which is no problem to me, my frame's fine.
Thanks for the input guys, very much appreciated.
Gaz Thumbs Up
Josh|RD125LC
PostPosted: 17:15 - 12 May 2005    Post subject: Reply with quote
I hope Mr.TZR is still on your books! Razz
Get that baby going. Cool
RD125LC Pictures
Gazdaman
I did a trackday!!!
PostPosted: 23:26 - 12 May 2005    Post subject: Reply with quote
Don't worry, I will, keep an eye on my progress on the website in my sig, I'm just waiting till payday till I can afford to plough more money into it.
I'm £42 into my nonexistant overdraught at the moment, which sucks donkey balls.
Sourced some fork tops for it, just need to clean the carbs, new exhaust gasket, battery and chain, and it should be worthy enough to take for a short illegal thrash!
Then it's down to getting it MOT worthy, which should just mean sorting the completely f*cked electrics.
Gaz
Gazdaman
I did a trackday!!!
PostPosted: 11:33 - 13 May 2005    Post subject: Reply with quote
Just managed to pick up everything I need, bar a mirror for £40.
I love ebay Thumbs Up
So now a set of pattern mirrors, and I'm back on the road.
Need to twist the forks back into place aswell and all will be good.
Gaz
The last post was made 20 years, 318 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.95 - MySQL Queries: 16 - Page Size: 126.08 Kb
