ER5 hole in engine
proximity
PostPosted: 19:01 - 12 May 2005    Post subject: ER5 hole in engine Reply with quote
Anyone know what this is for, some kind of hole which smokes sometimes.
2004 Aprilia Tuono
instigator
PostPosted: 19:18 - 12 May 2005    Post subject: Reply with quote
Well, thats a new one Confused
Don't think mine has that and I don#t think yours should! Of course, I'm not sure..
iCraig
PostPosted: 19:41 - 12 May 2005    Post subject: Reply with quote
Its the spark plug drain hole.
All the EX500 engines (whether in the GPZ, ER-5, or KLE) have them, and I'd be pretty supprised if it didn't. Basically its there to drain away any water sat on the top of the engine.
wilberforce
PostPosted: 22:01 - 12 May 2005    Post subject: Re: ER5 hole in engine Reply with quote
I vaguely recall seeing on my dead GPz5. Is the smoke really steam? Just wondering.
One of the "Boys from the Wall"
numark1
Scared of girls
PostPosted: 22:03 - 12 May 2005    Post subject: Reply with quote
Looks to me like speed holes. Laughing Will probably increase your bhp by 10 and add an extra 15 mph. Wink
conpants
PostPosted: 22:04 - 12 May 2005    Post subject: Reply with quote
its a pencil sharpener
for instance:-
you have commuted to your office and have a report to file before 12:00, but that HB pencil is blunt and as usual the office pencil sharpener is missing and you dont want to go into another department to borrow theres, as you made a fool of yourself at the office party. therefore you goto your er-5 to sharpen your pencil and everything is fine
clever planning by kawasaki really
PostPosted: 22:21 - 12 May 2005    Post subject: Reply with quote
Yep, it is a drain hole for the recess the plug sits in. Ordinarily nothing should come out of here. If you are getting a lot of steam coming out it is likley that one of the two coolant pipes that go down through the top of the rocker cover is leaking. Water could get in there if you have been riding in very heavy rain but it is unlikley.
This is very common and is invariably caused by someone removing the rocker cover to check the vlave clearances at a service then failing to fit new o-rings (at 50p each) on the ends of the two pipes when they refit them.
They are easily replaced if this is a problem but you will have to drain the coolant to do it, after that it is a case of tank off, undo the two screws that hold the pipes in, pull the pipes out (up), replace the o-rings then reassemble and refill with coolant.
proximity
PostPosted: 23:38 - 12 May 2005    Post subject: Reply with quote
Ah that would make sense. I think it is leaking because it keeps drinking all the coolant.
Its my mates bike he just got yesterday, we thought it was some kind of dodgy mod.
2004 Aprilia Tuono
tony532
PostPosted: 23:43 - 12 May 2005    Post subject: Reply with quote
i bit like me thinking the drain hole on my exhaust was there because someone had drilled a hole in it to make it sound throatier
Embarassed
Zoffo
PostPosted: 12:43 - 13 May 2005    Post subject: Reply with quote
Embarassed
I remember spending half an hour trying to polish it off Embarassed
https://hyperbikes.forumsplace.com/
The last post was made 21 years, 119 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 64.14 Kb
