| proximity |
 proximity Crazy Courier
| mchaggis |
 mchaggis World Chat Champion
 Posted: 00:48 - 15 May 2005 Post subject: |
I've used Castrol GTX (not magnatech) since new in my 125, and never experienced any clutch slipping problems other than those caused by my fiddlings with the cable adjustment.
Whether it's good enough for an engine which will rev to 18-20k rpm is another matter. I'd be tempted to say yes, but don't actually know. It certainly shouldn't cause clutch slip, it's just the other performance I'd perhaps wonder about at silly engine speeds. ____________________ I must not be a troll...
Mmmm, Guinness
| proximity |
 Posted: 00:52 - 15 May 2005 Post subject: |
If it doesn't cause clutch slip then should it be ok if i replace it regularly because ive just found another few litres
My bike redlines at 15k ____________________ 2004 Aprilia Tuono |
| jimster |
 jimster Spanner Monkey
| mchaggis |
 Posted: 01:15 - 15 May 2005 Post subject: |
The magnatech oils are different in that they have special low friction additives specifically for car engines. Remember, cars have dry clutches, so the oil is purely for lubrication and cooling of the engine. The low friction additives will tend to cause slippage of the wet clutch in a bike.
(They're also unneccesarily more expensive, especially for low performance engines). ____________________ I must not be a troll...
Mmmm, Guinness
| proximity |
 Posted: 05:30 - 15 May 2005 Post subject: |
My old GPZ500s had a fresh fill of castrol GTX every 3,000miles for a total of 50k miles with never a problem, and I thrashed the knackers off it everywhere. I also used it in my CB125s and in the gearbox of my H100, no worries
I once put about a pint of magnatech in the GPZ (emergency top-up from a filling station, it was burning quite a lot of oil before we put new rings in it, due to being ridden flat-out everywhere) and the clutch started slipping at high revs. Stopped slipping again once it was drained and replaced with normal stuff.
One of our local driving examiners uses GTX in his work pan-euro and he is doing over 50k miles a year. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Kram |
 Kram World Chat Champion
 Posted: 16:10 - 15 May 2005 Post subject: |
Castrol GTX is what i use in the FZR6 and the CB650 Nighthawk. never had any problems, (and it's only £13.50 for 5 litres ) ____________________ FS1E -> SR125 -> CB400N -> CB650 -> FZR600 Genises -> VFR400 NC21 -> CBR900RR Fireblade -> Renault Clio 1.4 |
| bish777 |
 bish777 World Chat Champion
The last post was made 20 years, 333 days ago. Instead of replying here, would creating a new thread be more useful? |
