| gimpy limp |
 gimpy limp Nearly there...
 Posted: 17:59 - 14 May 2005 Post subject: float bowls draining themselves? |
can the screws wear on these? ever since I put the bike on it's side the other day it's been draining itself of fuel unless I cut off the fuel from the tank from the tank switch. I can't see how putting it on it's side would do this, but it might have also been from when I undone the screws to drain any old fuel that was in their. I've tightened them up as much as I can but it's still dripping out. It was fine before I done this.
https://img59.echo.cx/img59/4173/carb8dt.jpg
red one is what you unscrew, then it drains from the blue one. ____________________ -=[Sam/b]=- cx500's the only way to travel, we do it in style just like jimmy saville
msn addy - [email protected]
https://pre-auto.com/cx500/rat_and_survival_gallery_2006 |
| gimpy limp |
 Posted: 20:46 - 14 May 2005 Post subject: |
The two most likley causes are either the floats sticking or some muck having got stuck in the needle valve seat after dropping the bike swirled all the crud that likes to lurk in the bottom of your tank.
Try tapping the side of the float bowl with a deadblow hammer and see if that stops it. If that doesn't work I would be thinking about taking the carb off and checking the needle valve.
If your bike has a vaccuum fuel tap, you would have to question why this isn't working too as no fuel should go through it with the engine off unless you have set it to 'prime'. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| gimpy limp |
 Posted: 21:14 - 14 May 2005 Post subject: |
kk i'll give that a go next time it starts, it's actually stopped now but last time it stopped and come back again.
i actually blocked off the drain tube earlier-on with some wire and the petrol started coming through one of the carbs turned the tank off, took the wires out, turned it back on went away and when I came back seemed to be back to normal.
Hate not knowing what the problem is, if theirs somethign dodgy going on i'd rather fix it now rather than fix it when it's on the road. I think it's pretty easy to take the carbs off anyway. Might be worth doing if it starts again.
| bish777 |
 bish777 World Chat Champion
| Aikman666 |
 Aikman666 World Chat Champion
 Posted: 21:52 - 14 May 2005 Post subject: |
It could be a problem with the floats not closing the valve properly, when you take the carb off, take off the cover on the floats chamber, push the floats up and blow through the petrol pipe, if air is escaping then the valve isnt closing properly. Also check that it isnt just the seal on the chamber thats bust. good luck  ____________________ Will work for petrol
My Design Blog |
| gimpy limp |
| gimpy limp |
 Posted: 23:47 - 14 May 2005 Post subject: |
lol yeh I tried one of those but it wasn't having none of it
I got it off with a coping saw blade in the end, only needed a little pursuation with that came right out. ____________________ -=[Sam/b]=- cx500's the only way to travel, we do it in style just like jimmy saville
| mr.z |
 mr.z World Chat Champion
 Posted: 23:58 - 14 May 2005 Post subject: |
Check 100% all the tubes and connecings are on in the right place, i seem to remember somehting to do with that, or something blocked... somebody had the same problem... can't remember what it was i'll have a look see, might be worth posting on the boards (once everyone is back from scotland)... it was was at the last rally.. ummm.... ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| tonyyzf |
 tonyyzf Brolly Dolly
| tonyyzf |
| gimpy limp |
 Posted: 14:14 - 15 May 2005 Post subject: |
worth changing the oil you reckon to stop that happenning? seems to have stopped completely now, I just fired the engine up for the first time too runs nice. if I change the oil in theory any fuel that's got in their can't mix if it's fresh oil? not sure?
the engine hasn't been started for some time btw and it's only had fuel in the tank for about 3 days (was empty before) ____________________ -=[Sam/b]=- cx500's the only way to travel, we do it in style just like jimmy saville
| mr.z |
 Posted: 14:31 - 15 May 2005 Post subject: |
i'd reccomend puting a filter on anyways, if its been empty for a long time it can get rusty, petrol keeps it free of rust believe it or not..
Has the oil been changed anyway? first thing should be done is an oil change + filter, be carefull of the filter bolt (are easy to round off) and be sure not to miss the spacer in there...
Did you get that manual off dave? my internet connection is working again now btw  ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| gimpy limp |
 Posted: 14:37 - 15 May 2005 Post subject: |
eye, the oil's been changed but I don't mind doing it again if it insures the engine's safe, would one of them fuel filters for the car do the job you reckon? I've got a few of them i've never used.
yeh got the manual, so useful it is, if anyone else asks you for it zero let me know and i'll let them have the link to it on me server for them to download, i've got plenty of upload/download bandwith on their. ____________________ -=[Sam/b]=- cx500's the only way to travel, we do it in style just like jimmy saville
 Posted: 14:40 - 15 May 2005 Post subject: |
An inline fuel filter will certainly help keep muck out of the carb. I have used those orange paper car ones with no problems before although I believe some bikes don't like them. A maggot lump is virtually a car engine anyway so I wouldn't forsee any problems  ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| bish777 |
| tonyyzf |
The last post was made 21 years, 118 days ago. Instead of replying here, would creating a new thread be more useful? |
