| Black Knight |
 Black Knight World Chat Champion
 Posted: 13:26 - 16 May 2005 Post subject: LED indicators - fitting advice |
I was thinking about getting some of those ultra bright LED indicators.
Are thay a straight swap or is some tinkering with the electrics needed?
Anybody got them? How much did they set you back and are they worth it?
Thanks  ____________________ Where does a turn end? 'Where you can do anything with the gas you want to, where you are brave again, where your attention is free from the turn, where you are sure you can do it better next time; that's the end' - Keith Code. |
| map |
 map Mr Calendar
 Posted: 13:37 - 16 May 2005 Post subject: |
Because of the voltage difference a common fault is that, depending on the age of the bike, they flash too fast. There is an another aftermarket blackbox that you insert and this corrects the flash rate.
Just done a google - Acument do a blackbox if it's required - click here for info.
HTH  ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
| Black Knight |
| map |
 map Mr Calendar
| Raffles_Gentleman Thug |
 Raffles_Gentleman Thug Trackday Trickster
 Posted: 13:47 - 16 May 2005 Post subject: |
I remember when changed my stock indicators on my ex-RS250 to aftermarket brighter ones, I had to buy a new higher wattage flasher unit, it cost £7 from my local bike shop and was simply a case of unplugging the old one and plugging in the new one.
I spent a good 25 mins looking over the manual looking for the flasher unit with no joy, before a mate pointed out i could just turn on the indicators and listen for the clicking sound the unit made!  ____________________ "Is sir addressing me or is he masticating on a house brick? Because either way sir loses his teeth." |
The last post was made 21 years, 118 days ago. Instead of replying here, would creating a new thread be more useful? |
