Chains
proximity
PostPosted: 00:58 - 16 May 2005    Post subject: Chains Reply with quote
Seems my chain has stretched, its like sitting on the sprocket at the top, but towards the bottom its moves out of sync so it sits on top of the sprocket cog things.
Anyway my question is, which of these do i get, as i know nothing about makes of chains:
Chain Standard Izumi £15
Chain Izumi Heavy Duty £17
Chain Standard Grade DID £20
I am avioiding the generic makes, I thought the izumi heavy duty would be the best bet, as good as the DID?
2004 Aprilia Tuono
tatters
Exxon Valdez
PostPosted: 02:05 - 16 May 2005    Post subject: Reply with quote
personaly l would have a DID as they seem to last longer plus l,ve never had a DID snap. (unlike IRIS)
Chriss
PostPosted: 02:11 - 16 May 2005    Post subject: Reply with quote
Same here, never had a DID chain snap, even though my last DID was *highly* abused. Embarassed
TheShaggyDA: I've got 3 or 4 pairs that predate my wife, so at least 11.5 years old.
PostPosted: 03:02 - 16 May 2005    Post subject: Reply with quote
I'd have to say Kawasaki OEM, the chain outlived lots of other parts on my ZX6R such as the engine and the fairing. Laughing Razz
About the same as me then, I've also had an ISIS (think thats what they're called) chain snap, when on M4 which was fun. Neutral
Anything but ISIS gets my vote, I'd get the DID over the Izumi one as it's just £3 more.
iCraig
PostPosted: 05:59 - 16 May 2005    Post subject: Reply with quote
I have a Tsubaki one on the GPZ, seems well made and was reasonably priced too, though its only done about 150 miles so far since putting it on a month and a half ago.
Also if no ones pointed it out to you yet you must replace the sprockets if you intend to replace the chain.
MCRR are good for C&S Kits and they're well priced too.
Black Knight
PostPosted: 07:20 - 16 May 2005    Post subject: Reply with quote
£20? Shocked
That seems very cheap mate. Is is a small engine or something? The heavy duty X ring chain I bought for my 600 was £50.
I didn't do the sprockets with the chain. TBH the damage used sporckets would do is minimal. Much better off spending your money on a decent paddock stand, chain cleaner and quality lube.
Where does a turn end? 'Where you can do anything with the gas you want to, where you are brave again, where your attention is free from the turn, where you are sure you can do it better next time; that's the end' - Keith Code.
proximity
PostPosted: 17:30 - 16 May 2005    Post subject: Reply with quote
So you all reckon i should order the standard DID.
I thought the heavy duty one would be a bit stronger, or are izumi crap?
2004 Aprilia Tuono
proximity
PostPosted: 17:37 - 16 May 2005    Post subject: Reply with quote
Here is a picture of the problem.
The sprocket seems fine so has the chain just stretched? I never noticed it before.
2004 Aprilia Tuono
Black Knight
PostPosted: 17:39 - 16 May 2005    Post subject: Reply with quote
Can't inspect the sprocket from that picture but you definetly need a new chain asap!
proximity
PostPosted: 17:45 - 16 May 2005    Post subject: Reply with quote
Here is the sprocket. The chain seems to be loose all the way round not getting worse so maybe it needs tightening.
2004 Aprilia Tuono
Black Knight
PostPosted: 17:49 - 16 May 2005    Post subject: Reply with quote
Needs to be a pic from the rear mate, looking towards the front of the bike.
So you can see the 'n' shape, or not of the sprocket.
proximity
PostPosted: 17:53 - 16 May 2005    Post subject: Reply with quote
Oh right i see Confused
2004 Aprilia Tuono
ash t
PostPosted: 17:56 - 16 May 2005    Post subject: Reply with quote
If you are getting a new chain, you might as well change the sprockets too!!
When You're Starting To Choke, Take Some Pills With Your Coke, Its Hyserical
quik_d
PostPosted: 18:34 - 16 May 2005    Post subject: Reply with quote
looking at that sprocket i'd say change that at the same time otherwise it'll promptly knacker the new chain. those teeth look rather worn!
LOOK AT DAT M8 WELL LUSH A PARROT INT IT
tatters
Exxon Valdez
PostPosted: 18:37 - 16 May 2005    Post subject: Reply with quote
you might be able to get a DID chain and sproket kit for about £70-80
bish777
PostPosted: 18:38 - 16 May 2005    Post subject: Reply with quote
Cant you tighten the chain? Its hard to believe youve run out of adjustment????
the sprocket is worn but only about half worn i'd say as the teeth arent nearly read to fold over?
But yes buy a new sprockets with the chain.
Ive used EK chains and was happy with them.
GSXR1100J
proximity
PostPosted: 18:47 - 16 May 2005    Post subject: Reply with quote
Ok thanks guys.
2004 Aprilia Tuono
cagiva gezzer
PostPosted: 21:26 - 16 May 2005    Post subject: Reply with quote
Bike torque racing is where i got my last set from. £20 for a chain? I spent more than that on my moped! Don't get cheap chains as they just stretch in no time. If you can save your pennies, get the 'o' ring ones.
Just had a look and they don't list a zeal, but a std AFAM chain and sproket kis for a 125cc (520x104) is £43..... rising to £63 for a decenbt o-ring.
The last post was made 21 years, 114 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.39 - MySQL Queries: 13 - Page Size: 95.1 Kb
