how do i know when my nsr 03....
JakeyC
PostPosted: 16:47 - 18 May 2005    Post subject: how do i know when my nsr 03.... Reply with quote
is out of coolant fluid? is it the display low down on the side of the bike that has a max over min Display
Plus what chain oil do i need for it?
mchaggis
PostPosted: 17:18 - 18 May 2005    Post subject: Reply with quote
No idea about the specifics of checking the NSR coolant level, but I've found that "3-IN-ONE with PTFE" no less, from Halfords for £3 (I think) is the best stuff I've used so far. Castrol chain wax is horrible and dries out really quickly, not to mention going green.
If it were a four-stroke and you were changing the oil reasonably frequently, dousing it in old engine oil every week or two appears to be a good way of doing it too.
I must not be a troll...
Mmmm, Guinness
tokarev
PostPosted: 17:20 - 18 May 2005    Post subject: Reply with quote
For a coolant check, open your tank and you will see the reservouir. The reservouir on the left is the coolant tank - the one on the right is the engine oil reservouir. It is semi-transparent so just make sure the level of fluid in it is above the minimum line on the reservouir.
Is this on the right hand side near the foot peg? If it is then that is the gear-box oil level, check that when the engine is off otherwise it looks empty.
As for Chain oil you can use normal gear oil for it or go to halfords and buy some chain-lube. Thumbs Up
JakeyC
PostPosted: 18:03 - 18 May 2005    Post subject: Reply with quote
cheers guys thanks for the fast response Thumbs Up
The last post was made 21 years, 165 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.96 - MySQL Queries: 13 - Page Size: 40.7 Kb
