| Jonathan |
 Jonathan Renault 5 Driver
 Posted: 16:18 - 22 May 2005 Post subject: My bike is dying |
I have problems with my bike, im totally useless and willing to learn, so i hope you guys/gals can help me...
When i get to 6000rpm my bike starts stuttering really badly, my rev counter also starts going crazy when it gets to 6000rpm... i left it out in the rain last night...
i dont know what the problem is and its driving me mad...
its either you guys or take it to the garage...
Hope anyone can assist me in fixing the problem...
Thanks Jon  ____________________ Honda NSR125R ... - Awaiting Selection - ...
My Motorbike Website > https://www.freewebs.com/jonsbikes |
| stinkwheel |
 Posted: 16:36 - 22 May 2005 Post subject: |
Sounds like there is either a short circuit or a bad earth connection.
If it has just started doing it since it got a soaking, I would get yourself a big can of WD40 and spray it over all the bits of wiring you can find including in connector blocks, the back of the clocks, the ignition coils and switches. The WD in WD40 stands for Water Displacing, the stuff was actually designed to force water out of electrics.
If this doesn't fix it, I would start checking your frame earths, anywhere the end of a wire is bolted to the frame. Undo them, clean up the metal to metal connection with some emery paper and refit them with a smear oif copper grease over them. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Jonathan |
 Posted: 16:49 - 22 May 2005 Post subject: |
Ok, i'll give that a try, thanks for the advise....
*waits for the rain to go off"  ____________________ Honda NSR125R ... - Awaiting Selection - ...
| Jonathan |
 Posted: 22:56 - 25 May 2005 Post subject: |
Tried alot of things now. Problem still occurs...
Its ok up to 6000, then it stutters, so i have been dropping a gear to get past it, but then it does the same about 10,000 revs...
I havent got to the worst yet ...
Bike starts stuttering home and cuts out at the top of my road. I get it to the door, and check it out,
OOPS i have no fuel. So i whack it to reserve and just about get it started, then it cuts out just of the petrol station ... it wont start.
I push it to the petrol station and fill it up. Now it doesnt start, i try everything i can until i result in ringing break down service which comes free with my insurance, so i wait for an hour which wasnt bad, i get it brought home, and now its in my backgarden with a warm cover over it, officially announced "dead".
I dont know what to do. Shall i call a Mobile Mechanic instead of taking it to a garage which i dont know how to do seeming the bike wont start ...
i wouldnt mind but ive only had it a month ((
Any advice would be much appreciated.
Thanks, Jon ____________________ Honda NSR125R ... - Awaiting Selection - ...
| gimpy limp |
 gimpy limp Nearly there...
 Posted: 23:37 - 25 May 2005 Post subject: |
some of my cars are right lil madams when the petrol runs dry, the one won't start for 3 sometimes 4 days if I let it run dry before filling it back up. Maybe it's that, try it in a few days an see. Maybe you've flooded it (quite easy to do)
check your compression before you pronounce it dead, so long as it turns over you can test it. Also the usual stuff check for spark, dodgy earths, fuel getting to the carbs etc ____________________ -=[Sam/b]=- cx500's the only way to travel, we do it in style just like jimmy saville
msn addy - sam.barwick@ntlworld.com
https://pre-auto.com/cx500/rat_and_survival_gallery_2006 |
| Stevie B |
 Stevie B Crazy Courier
| gimpy limp |
 Posted: 23:45 - 25 May 2005 Post subject: |
oh, jump start it too after you've made those checks. 9 times more likely to start that way. I jumped my bike and it started on 1 cylinder (1 coil isn't sparking) but wouldn't start just from the switch/battery by itself. ____________________ -=[Sam/b]=- cx500's the only way to travel, we do it in style just like jimmy saville
| Jonathan |
 Posted: 23:49 - 25 May 2005 Post subject: |
thanks for the replies, ill have a good crack at it after work tommorow...  ____________________ Honda NSR125R ... - Awaiting Selection - ...
| tokarev |
 tokarev World Chat Champion
| JonT |
 JonT Crazy Courier
| dansuresh |
 dansuresh Scooby Slapper
| Jonathan |
 Posted: 23:00 - 26 May 2005 Post subject: |
Thanks lads, im totally useless person when it comes to bikes, i'll have to give it a go though ... probably fuck it all up
some mobile mechanic said he will derestrict it and fully service it for £150
shall i ? ____________________ Honda NSR125R ... - Awaiting Selection - ...
The last post was made 20 years, 309 days ago. Instead of replying here, would creating a new thread be more useful? |
