help please because....
dransy
PostPosted: 23:33 - 24 May 2005    Post subject: help please because.... Reply with quote
on the way home from work my bike totally died
i dunno y, i warmed it up like normal drove round industrail estate to make sure its ok like normal got to junction it cut out , *its done it before though* so i pulled it into side waited abit fired it bak up all was well drove around block again was fine got about a mile home goin down a hill was just about to hit powerband in 3rd gear got to 8thousand rpm and bike just totally dies , back wheel locked up so i pulled clutch in rolled down hill and up overside about half way up hill pulled into side again waited it wudnt start
waited some more wudnt start so i pushed it up hill and used some nice ladys phone at this house and rang my uncle before he got here i waited cos it sounded like engine was flooded as he got here it started up he had ago wen he hit powetrband it cut out on him
any ideas?
thanks
ZRX61
Victor Meldrew
PostPosted: 23:38 - 24 May 2005    Post subject: Re: help please because.... Reply with quote
dransy wrote:
any ideas?
thanks
Yes, it's spelled "wouldn't" hth Smile
Frost
PostPosted: 23:58 - 24 May 2005    Post subject: Reply with quote
Sounds like it has no oil in it or it's running out of fuel.
Clogged fuel filter, water in your fuel, blocked jets, knackerd oil pump are all possibles.
First i'd make sure you actually have some oil in it first Wink Laughing
dransy
PostPosted: 00:02 - 25 May 2005    Post subject: Reply with quote
im really low on fuel i was goin to fill up but i never made it,
i dont know much about the mechanical side just how to clean jets and stuff
so is it the fuel?
Gazdaman
I did a trackday!!!
PostPosted: 00:29 - 25 May 2005    Post subject: Reply with quote
Well fuel would be the first thing (and easiest thing) to check! Just fill her up and see what happens.
Gaz
ZRX61
Victor Meldrew
PostPosted: 00:31 - 25 May 2005    Post subject: Reply with quote
The first thing to do then is fill the bugger up with petrol Rolling Eyes
JO5H
PostPosted: 00:41 - 25 May 2005    Post subject: Reply with quote
When i had my bike it used to cut out all the time i didnt no what it was, i was riding with a mate so he rode home and got my mom to pick me up cause i thoght im gonna have to leave my bike here which i didnt want to do . The time she got here which was about 25mins i thought to my self fuel tap put it on reserve and it started up straight away.
you proberbly didnt have the same problem as me so i dont have a clue what the problem with your bike.
You could clean the carb or check the fuel pipe that nothink is clogging it up, i dont no.
josh.
********SUZUKI GSX-R 600 SOON!********
add me to msn and we can chat. [email protected]
RS125_Tecky
PostPosted: 05:54 - 25 May 2005    Post subject: Reply with quote
BUT WHY WOULD THE BACK WHEEL LOCK UP IF HE'S ONLY RAN OUT OF PETROL????
Aikman666
PostPosted: 10:02 - 25 May 2005    Post subject: Reply with quote
...gee i dunno, BECAUSE ITS IN GEAR?!
Will work for petrol
My Design Blog
cqueen
PostPosted: 10:37 - 25 May 2005    Post subject: Reply with quote
even though it was in gear i doubt that is why it locked up, esp as he was just doing 8k in 3rd, the speed he was going would have kept the engine turning over but not firing. like when you are bump starting, back wheel doesnt lock up.
although eventually it would lock up, but as he said he pulled the clutch in
feef
Energiser Bunny
PostPosted: 10:47 - 25 May 2005    Post subject: Reply with quote
what kind of bike is it?
if it's a 2 stroke, it sounds like a partial seizure.
check you've got enough oil in your mix.
if it's a 4 stroke.. I dunno...
Mudskipper wrote: feef, that is such a beautiful post that it gave me a lady tingle Laughing
Windchill calculator - London Bike parking
Blog and stuff - PlentyMoreFish dating
cqueen
PostPosted: 10:56 - 25 May 2005    Post subject: Reply with quote
I'd say so too. get your spanners polished!
dransy
PostPosted: 00:36 - 26 May 2005    Post subject: Reply with quote
2 stroke rs 125
filled her up today
seems ok but i had fuel in just not loads but i had some in
but shit myself when back wheel locked up
gimpy limp
PostPosted: 00:55 - 26 May 2005    Post subject: Reply with quote
get some new oil and a new filter in their then boyo (don't change oil without a new filter or you get all the old bits floating around in your new oil) If you find metal shavings in the old filter (copper or silvery flakes mainly) engine has probably damaged its crankshaft or big-end bearings (I think).
-=[Sam/b]=- cx500's the only way to travel, we do it in style just like jimmy saville
msn addy - [email protected]
https://pre-auto.com/cx500/rat_and_survival_gallery_2006
jayluvmito
PostPosted: 01:06 - 26 May 2005    Post subject: Reply with quote
no oil filter. its 2t
one day...
ZRX61
Victor Meldrew
PostPosted: 01:08 - 26 May 2005    Post subject: Reply with quote
Mechanics 101:
The oil is pumped to small ports in the engine, one of these is usually between the carb & the bottom end, the petrol mixes with the oil as it passes over the port & distributes it everywhere that the fuel goes, ie, all around the crank/big end, up the transfer ports & into the cylinder where it gets on the liners to prevent seizure....
Run out of petrol & the oil isn't gonna get where it's supposed to go, ergo: ya run out of petrol & the fucker seizes, any questions or shall I type slower?
cqueen
PostPosted: 12:33 - 26 May 2005    Post subject: Reply with quote
if you run out of petrol, your engine stops firing, it wont instantly seize. id guess that you didnt have enough oil in your fuel mixture. you can fix a seized engine farely easily if you got some spare time and some space
ZRX61
Victor Meldrew
PostPosted: 15:04 - 26 May 2005    Post subject: Reply with quote
You are of course perfectly corrrect,. it will carry on for about another 40ft before it locks up Rolling Eyes
cqueen
PostPosted: 15:25 - 26 May 2005    Post subject: Reply with quote
nah, besides he wasnt out of petrol anway.
The last post was made 21 years, 161 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.67 - MySQL Queries: 13 - Page Size: 103.34 Kb
