seat lowering.. I seem to have a problem
izzi81
PostPosted: 13:38 - 25 May 2005    Post subject: seat lowering.. I seem to have a problem Reply with quote
The one problem I've had with the zx6r is that it's a wee bit high. I don't mind that much, but I know I'd feel more confident getting the balls of both feet on the ground (or even my whole foot!). Currently it's more like just my toes on the ground.
I did some investigating and getting the seat lowered sounded like the answer to my problem. So I finally got a cheap spare seat on ebay, sent it away to be altered, got it back the other day and have just tried putting it on the bike.
Hmmm.
I got 2" taken off the seat, which I thought had to be enough to at least go from toes to balls of feet on ground - the guy who altered it for me said when he did his he went from toes to feet flat on the ground with 3.5" taken off. But it seems to have no made much difference at all, except now it puts noticeable pressure on my inner thighs because there's less.. shape to the seat, so it's not as comfy (thank goodness I got a spare adjusted!!) Put the seats side by side and there's definitely a height difference, probably 2".
So what's gone wrong? Has anyone else done this to a bike seat - what did you find? Is this something to do with the difference between men and women re. shape of seat? (I did think about attempting diagrams of me sitting on my bike but thought that was getting a bit silly!)
There was me thinking this was the solution to all my problems, and yet it seems to be another costly experiment Sad
"The problem with the French is they have no word for 'entrepreneur' " George W Bush
Age doesn't matter unless you're a cheese
https://www.bikepics.com/members/izzi81
Sadie
PostPosted: 13:40 - 25 May 2005    Post subject: Reply with quote
It would appear that your legs are not long enough! Laughing
With experience comes age.
Suzuki
Roger
PostPosted: 13:43 - 25 May 2005    Post subject: Re: seat lowering.. I seem to have a problem Reply with quote
izzi81 wrote:
I don't ming that much
LMFAO! Laughing
You could try lowering the rear shock somehow, or replacing it with a lower one?
<Simple> no I'm shaven Jon Razz
<Simple> it is a big enough hole.. I'll leave it now
Ride: 1999 Suzuki GSXR600 (yellow/black) IRC: Stats - Relationship Map
Bendy
Mrs Sensible
PostPosted: 13:44 - 25 May 2005    Post subject: Reply with quote
I got a chunk taken out of mine and because the 'hump' is gone it does force your legs out further and thus remove some of the benefit.
Would probably be less comfy too, if I didn't carry my own padding with me at all times.
izzi81
PostPosted: 13:45 - 25 May 2005    Post subject: Reply with quote
I thought that was the point of lowering the seat Laughing Why does it work for other people then, or do they just have very wide legs?!
Let me fix that spelling mistake too Laughing
izzi81
PostPosted: 13:47 - 25 May 2005    Post subject: Reply with quote
yes, exactly what mine is doing. I will have to take it out for a test run (when it is not pouring) to see what it's really like but I'm not that hopeful... I have some personal padding but not a huge amount!
Bendy
Mrs Sensible
PostPosted: 13:55 - 25 May 2005    Post subject: Reply with quote
Do give it time, mine felt way weird at first.
Not sure how much difference it really makes, but I reckon I can paddle my bike backwards a bit better than before. So even if that 2 inches out the seat gives you half an inch by the time you reach the ground, it could be worthwhile.
Sadie
PostPosted: 13:56 - 25 May 2005    Post subject: Reply with quote
I just have very long legs - makes things much easier! Laughing
PostPosted: 14:09 - 25 May 2005    Post subject: Reply with quote
Has he taken 2" from all over the seat? The back included.
I would consider trying to lower the shock /and/ the forks a little bit (to keep the handling the same).
izzi81
PostPosted: 14:25 - 25 May 2005    Post subject: Reply with quote
Yes it's a general 2" reduction. I have thought about mechanical adjustments but I was always worried about the handling, and also whether it was really worth that level of tinkering!
PostPosted: 14:31 - 25 May 2005    Post subject: Reply with quote
Common problem seems to be that as you sit lower you are closer to the wider bits of the bike, so your legs are forced to go out before going down.
Also the older foam has probably softened with age.
Mrs Kickstart
PostPosted: 14:47 - 25 May 2005    Post subject: Reply with quote
Hi,
I find the width can make a big difference to how long my legs appear.
P&P seating in birmingham https://www.ppseat.co.uk/ can put gel pads in to the seat so it can be really low and fairly comfortable, we had this done for the bandit but it is not cheap.
Give it a bit of time, I found the ZX6R to wide.
bye
C
PostPosted: 16:01 - 25 May 2005    Post subject: Reply with quote
Dropping the forks in the yolks and reducing the rear preload will probably make pretty much no difference to the handling, I would have though... aslo is free and easy to do Smile.
Mr C
PostPosted: 17:14 - 25 May 2005    Post subject: Reply with quote
it's possible to just lower the whole bike by a couple of inches by fitting longer tie bars to the rear suspension links south of the shock
check on ebay or get someone to knock some up in stainless, you will only need about 15mm longer tie bars to drop the bike a couple of inches
mine is now fully adjustable (these are expensive - £120) but I can slam my bike down for racing until the the fairing is nearly touching the ground
187.3bhp = 201mph
Mr C
PostPosted: 17:15 - 25 May 2005    Post subject: Reply with quote
and what G says at the front, drop the forks a bit or it will be nose high and slow steering
187.3bhp = 201mph
PostPosted: 17:37 - 25 May 2005    Post subject: Reply with quote
While loads of people get away with it, due to the rising rate linkage at the back you will affect how the rear suspension reacts if you lengthen the dog bones or (even worse) slacken off the preload. Using longer dog bones at least means you then have the full range of adjustments on the shock to compensate.
Hagon sell (for about £250) customer shorter shocks to lower the seat height.
One thing to watch out for if you do drop the suspension is to ensure that the side stand will still work and not hold the bike too close to vertical (or even lean it the wrong way).
Mr C
PostPosted: 21:54 - 25 May 2005    Post subject: Reply with quote
depends how far you go Keith
an inch or so shouldn't affect ride quality that much
I wouldn't dare ride mine fast on the road with it lowered as far as it is
mind you I do sometimes end up at about 80 coming round the corner at the end Embarassed
the side stand is a valid point, although mine was ok down to about 3" lowered, now it really is slammed it has a couple of inches cut out of the sidestand
btw - these are the adjustables
187.3bhp = 201mph
Rob
PostPosted: 21:58 - 25 May 2005    Post subject: Reply with quote
Daytona do a boot that has an extra 2cm in the sole. They are called M Star. Might be worth a look for you?
Love is 1050cc Smile
PostPosted: 22:28 - 25 May 2005    Post subject: Reply with quote
Mmmm, nice. £120 you say? Where from? Could be useful for slowly dropping the height for an acceptable compromise. Do you need longer suspension bolts (as the ends are rather wider than the standard dog bones).
jayluvmito
PostPosted: 23:19 - 25 May 2005    Post subject: Reply with quote
most engineering firms make these, just a ally/stainless bar with rosejoints in the end. wherabouts are you kickstart? i kno a few good bike engineers we have had dealing with-depends wher yuo are..
one day...
PostPosted: 23:32 - 25 May 2005    Post subject: Reply with quote
Stafford, but the only local small engineer I know of has closed up shop (ill health).
Getting fixed ones made up would be easy enough, but getting threaded / rose jointed ones is a touch more difficult.
jayluvmito
PostPosted: 23:39 - 25 May 2005    Post subject: Reply with quote
hmm, stafford sounds like oop north to me, lol.
if you speak to a guy called daz at www.broscomb.co.uk based in oxford, i think its a fair trot from you, but his work is top notch and fair priced. if not try streetfighters magazine, plenty off small engineering firms in their which specialize on bike parts.
a threaded tit bar isnt realli a nard thing to make, just making sure the right grade of material is used, splitting at 130mph wouldnt be nice... unfortunetly most the engineers we use are small time ones down south.
one day...
PostPosted: 23:59 - 25 May 2005    Post subject: Reply with quote
Cheers, although Oxford is 100 miles away. One breaking really does not appeal.
izzi81
PostPosted: 02:19 - 26 May 2005    Post subject: Reply with quote
thanks for all the tips - threads like this make me wish I knew a bit more about the mechanics of everything! Guess I should go off and read my Haynes Laughing
Might have to look into those boots.. nothing technical about those!!
Mr C
PostPosted: 10:41 - 26 May 2005    Post subject: Reply with quote
they were imported from the US through Big CC Racing in Wokingham - although many others do them
making them shouldn't be hard, although they don't actually need a Rose joint in the end, it's not a bearing as such - just a round hole. one needs to be a left hand thread though obviously Wink
no the bolt isn't long enough to be totally in safety - but I just tightened it up and forgot about that - until you just mentioned it Embarassed
187.3bhp = 201mph
The last post was made 21 years, 154 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 131.34 Kb
