| BlueNinja |
 BlueNinja Trackday Trickster
 Posted: 18:38 - 25 May 2005 Post subject: SR 125 exhaust build.. another BlueNinja project. |
I am currently in the process of producing a new exhaust system for a Yamaha 125. Took me 4 hours to make the small manifold-downpipe section, as I have to cut and weld this from 8mm steel, and 2.5mm pipe.
The exhaust is from a car, and I gas welded a new outlet port onto it, which was also heat treated. The system will be straight through, so pretty loud.
So.. here are the pics!!
This is the old system, it was a bit rusty around the opening, and sounded like pees being shaken in a tin can.. Improvment needed I thought..
https://img.photobucket.com/albums/v228/raider2/SR%20exhaust/a9bfc57a.jpg
I decided I would make a completley new system.. this ment even producing the manifold, and down pipe, rather then welding a new can onto the old system.. work starts here:
https://img.photobucket.com/albums/v228/raider2/SR%20exhaust/d67383d1.jpg
The old manifold has a gasket which is pushed in by a lip on the pipe, and then a clamp holds the pipe and gasket tightley in. So I would have to get the correct sizes, or it would blow at this point.
Here is the pipe.. and a peice of steel to produce the manifold part from.
The pipe is from a car, and I Oxy welded the end pipe on, and lightley heat treated it to give it some colour.
https://img.photobucket.com/albums/v228/raider2/SR%20exhaust/89feef1b.jpg
I will have to get this peice of steel, into the shape of this old manifold.. doh..
https://img.photobucket.com/albums/v228/raider2/SR%20exhaust/b736410f.jpg
So I scribed out what looked about right, and then got a grinder onto it.
https://img.photobucket.com/albums/v228/raider2/SR%20exhaust/b9ba67e7.jpg
Not a bad shape.. after the shape was fine tuned with a file, I cut a strip of pipe out, the correct length to puch the gasket into the head correctly when tightened up.
https://img.photobucket.com/albums/v228/raider2/SR%20exhaust/8aa2e409.jpg
https://img.photobucket.com/albums/v228/raider2/SR%20exhaust/90658a8a.jpg ____________________ Big Kawasaki ZXR 400 project here:
https://www.theundertaking.com/index.php?showtopic=483
| BlueNinja |
 Posted: 18:39 - 25 May 2005 Post subject: |
Then welded the peice of pipe on, drilled out the manifold bolt holes, and began drilling/filling out the exhaust hole in the manifold block.
https://img.photobucket.com/albums/v228/raider2/SR%20exhaust/69712303.jpg
Next, welding the pipe off the manifold, into the down pipe
https://img.photobucket.com/albums/v228/raider2/SR%20exhaust/birds030.jpg
https://img.photobucket.com/albums/v228/raider2/SR%20exhaust/birds021.jpg
Quickly bolted it onto the head to check.. it fitted..
https://img.photobucket.com/albums/v228/raider2/SR%20exhaust/birds022.jpg
So far, so good.. now it gets tricky... I have to make a bend, without a pipe bender, so I did this by welding wedges together untill I had what looked to me like the rite angle.
So, I managed to cut and weld together this peice
https://img.photobucket.com/albums/v228/raider2/SR%20exhaust/birds023.jpg
https://img.photobucket.com/albums/v228/raider2/SR%20exhaust/birds024.jpg
Next pipe, the down pipe being fitted here: I alwas pup a little blob of weld on to hold it in place, put it on the bike, check it.. check it again, if its ok, fill the seam with weld. If not, pull it apart.
This fitted.. so it was welded together.
https://img.photobucket.com/albums/v228/raider2/SR%20exhaust/birds025.jpg
https://img.photobucket.com/albums/v228/raider2/SR%20exhaust/birds026.jpg
Need to fix the next pipe on now, with a pipe wedge to get the correct angle
https://img.photobucket.com/albums/v228/raider2/SR%20exhaust/birds031.jpg
I now have this:
https://img.photobucket.com/albums/v228/raider2/SR%20exhaust/birds032.jpg ____________________ Big Kawasaki ZXR 400 project here:
https://www.theundertaking.com/index.php?showtopic=483 |
| Gazdaman |
 Gazdaman I did a trackday!!!
| BlueNinja |
| BlueNinja |
| mchaggis |
 mchaggis World Chat Champion
 Posted: 18:57 - 25 May 2005 Post subject: |
Excellent stuff. It doesn't run lean or anything now does it though? ____________________ I must not be a troll...
Mmmm, Guinness
| BlueNinja |
| palmer |
 palmer Fiddled Kiddy
| BlueNinja |
 Posted: 20:56 - 25 May 2005 Post subject: |
Infact yes! low and top end improved.. middle range the same though.
The bike now reaches 65mph on a flat road, rather then just down a biiig hill. Pulls a lot harder at low speeds too. In the process of tweaking mixture settings.. but its running very well. ____________________ Big Kawasaki ZXR 400 project here:
| cagiva gezzer |
| rizo9 |
 rizo9 Nova Slayer
| m i k e |
 m i k e Could Be A Chat Bot
 Posted: 00:17 - 26 May 2005 Post subject: |
Well done mate, just out of interest how old are you? And are you trainging to be some sort of engineer or something, cause you certainly know what your doing in the workshop!
Mike ____________________ Bom Chicka WAHHH WAHHHHHHH! |
| Richard1987 |
 Richard1987 Scooby Slapper
 Posted: 00:43 - 26 May 2005 Post subject: |
you have done Very well weldingwise if its only your second time welding before? i am doing welding at college, part of my first diploma motor vehicle corse at college and it is quite tricky. once youve got the hang it is quite easy and you ALWAYS find something than needs welding  |
| numark1 |
 numark1 Scared of girls
 Posted: 01:26 - 26 May 2005 Post subject: |
I think the dudes 16. Fucking impressive. My dad has a welder and i tried it loads of times. So fucking hard because you can't see.
Good job bing.  |
| BlueNinja |
 Posted: 09:10 - 26 May 2005 Post subject: |
17 as of May now.. and CBT booked for this saturday.. atlast things are on the way!
So, as said above, Im pretty keen on engineering, but my maths are too poor to move to another level, so I keep it as my hobby or build exhaust mounts for freinds at college. I am doing a motor vehicle + repair course at the moment, but im not liking the group im studying with much.
As somone sais above, that you cant see when welding, I know what you mean.. if you do it out in the sunshine you can see, but this is England and you dont have that often! So I grabbed a big lamp, and had it shining at my work.. then you can see it through the visor.
I know the bends should be smoother.. but Il need mre practice I geuss.. still, should have spent more time on it with the sander.
Hopefully il be able to buy a propper MIG welder once I have finished all my bike tests.  ____________________ Big Kawasaki ZXR 400 project here:
| Chr!S |
 Chr!S Nitrous Nuisance
 Posted: 09:53 - 26 May 2005 Post subject: |
| BlueNinja |
 Posted: 11:26 - 26 May 2005 Post subject: |
Been meaning to buy one for a long time.. I think itle be MIG first, then pipe bender.. should be able to build all kinds of stuff then ____________________ Big Kawasaki ZXR 400 project here:
| Chr!S |
| Josh|RD125LC |
 Josh|RD125LC World Chat Champion
 Posted: 00:30 - 28 May 2005 Post subject: |
Well done mate. I thought I was doing well by restoring my RD at 16, but you seem to be doing better than me thats great. Good work mate.
Looks like you also have a nice large room where you work, whereas I'm stuck to work in a tiny shed. Just wish I had a double garage like my uncle. I would love that. ____________________ Honda MBX50 | Yamaha RD125LC | Suzuki RG125F Lucky Strike | Suzuki GSF600S
RD125LC Pictures |
The last post was made 21 years, 133 days ago. Instead of replying here, would creating a new thread be more useful? |
