Adjusting your chain
dansuresh
PostPosted: 15:33 - 26 May 2005    Post subject: Adjusting your chain Reply with quote
My chain can no longer be adjusted by the swingarm, and I need to take out a few links.
How do I go about doing this?
Can I just use a hammer and pin to take out the rivets (bad description) on the loose link or should i buy a chain rremover thing?
Thanks
Dan
mchaggis
PostPosted: 15:35 - 26 May 2005    Post subject: Reply with quote
If your chain is so worn that it can't be further adjusted with the swingarm, it's time for a new one. Taking links out will only end in tears. Compare the cost of a new crankcase after the shortened chain has snapped against the cost of a new chain. The new chain will come out cheaper. You should change the sprockets at the same time.
I must not be a troll...
Mmmm, Guinness
Mr C
PostPosted: 15:37 - 26 May 2005    Post subject: Reply with quote
^^ wot he said ^^
187.3bhp = 201mph
dansuresh
PostPosted: 15:38 - 26 May 2005    Post subject: Reply with quote
ok
Thanks. When the new chain comes, will be an exact fit or will that also need to be adjusted lightly by taking links out?
Thanks
Dan
Black Knight
PostPosted: 15:41 - 26 May 2005    Post subject: Reply with quote
If you ask nicely, im sure if the shop has facilities they will remove the necessary links.
Where does a turn end? 'Where you can do anything with the gas you want to, where you are brave again, where your attention is free from the turn, where you are sure you can do it better next time; that's the end' - Keith Code.
mchaggis
PostPosted: 15:44 - 26 May 2005    Post subject: Reply with quote
If you get a standard chain and the standard sprockets for your bike, it should all just fit fine straight away.
Mmmm, Guinness
jayluvmito
PostPosted: 15:46 - 26 May 2005    Post subject: Reply with quote
change sprockets aswell
one day...
Finglonga
PostPosted: 23:33 - 26 May 2005    Post subject: Reply with quote
Exactly!
Never ever just put a chain on, you may as well throw money down the drain! The worn sprockets at best will eat the new chain, and at worst throw the chain and you down the road. Always fit as a set. Thumbs Up
Andy Sez....
F.Y.Y.F.F.
The last post was made 20 years, 315 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.82 - MySQL Queries: 13 - Page Size: 55.86 Kb
