| Kaben |
 Kaben World Chat Champion
 Posted: 16:49 - 27 May 2005 Post subject: Engine pro's and cons ?? |
Ok,been reading alot of bike mags and BCF and i see comments on different engines.But they all tend to assume a pre-attained knowledge of engines
What effect does the type of engine have on the stats of an engine? (i.e power,torque reliability etc?)
By this i mean singles, v-twins,flat twin,triples and inline fours.
Can anyone give me information on the pro's and cons for these engine types?
Kaben ____________________ Its Not a Melon, Its Clearly a Lime!!
Yamaha Fazer 600Now dead, MZ 125 SM
My Deviant Art homepage https://robabloke.deviantart.com/ |
| mr.z |
 mr.z World Chat Champion
 Posted: 17:04 - 27 May 2005 Post subject: |
There was a big article in ride a while ago, i'll try to dig it out...
The caracteristics of the engine are allot from the layout, but there are exceptions, it depends on the design just as much...
Also the number of valves, pushrods/or chain driven cams, even gear driven cams... cam profiles, fireing order, timeing, cylinder angles... allsorts!
Then theres the actual physical properties, like ground clearence on a bmw boxer twin... i.e. not allot of it... but compared to a buel vtwin they will be easyer to maintain certain bit of the engine i.e. valves and spark plugs e.t.c. you might not be able to get a v4 engine in a particular kind of frame either..
Less cyclinders generaly means less cost and less complexity of the engine, but also less power overall...
i.e. a 600 single will be pretty weedy compared to a 600inline 4 (like 50bhp or 90odd bhp) but the single will cost less, probably last longer and be easyer to maintain.
Personally i prefer twins, the sound is one thing, the feeling of the pull you get low down, i'd never use the howling full power of an inline4, but it still sounds good when you push it
My bikes engine is an bit of an odd one, a vtwin but inverse, similar to the motoguzzi, easy to maintain (for some aspects) like the bmw but more ground clearance, but top heavy... ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| Kickstart |
 Kickstart The Oracle
 Posted: 17:34 - 27 May 2005 Post subject: |
Whether it is a V, flat or inline engine is pretty irrelevant to the power / torque (but not to the amount and type of vibration).
Basically a longer stroke engine will give more torque, but will also limit the amount of revs (mean piston speed of about 26m/s is about the limit). A shorter stroke gives more revs (and power is revs x torque), but less torque and a poor combustion chamber shape so less efficient. More cylinders means that you can have a short stroke without making the size of the bore silly.
| Major_Grooves |
 Major_Grooves The Doctor
 Posted: 17:38 - 27 May 2005 Post subject: |
Interesting question. I've been meaning to ask the same thing as I really don't have a clue about the differences. ____________________ About me|@Major_Grooves|My company|Digg|Flickr |
| mchaggis |
 mchaggis World Chat Champion
 Posted: 17:39 - 27 May 2005 Post subject: |
How many cylinders?
The more cylinders you have for a given volume, the smaller each cylinder can be. Normally this is done with a large bore and a small stroke.
With a shorter piston stroke, the crankshaft can spin faster.
The smaller the cylinder, the lighter the piston. This lower inertia will allow higher piston speeds.
For the same capacity and piston speed, a multicylinder engine will produce more power than a single cylinder engine.
More cylinders yields a higher frequency of power impulses, so the power output is smoother and more consistent.
A single cylinder with the same xs area as the total xs areas of a multi cylinder engine will develop more torque.
Smaller cylinders have a larger surface area for their volume, so will cool better. That allows a higher compression ratio to be used, yielding better thermal efficiency.
Lighter reciprocating components resulting from more cylinders allows the use of a lighter flywheel, so acceleration response improves linearly with the number of cylinders. (As long as the total engine volume is the same).
As the number of cylinders and engine length increases, torsional vibration becomes an ever larger problem.
The more cylinders you have, the greater rotational and reciprical drag there is to overcome.
Large numbers of cylinders make mixture distribution with carburettors more difficult.
The more cylinders, the more complexity, and the more cost!
Which arrangement?
Single cylinder - thumper (eg KLR650, F650, almost any small bike)
A power stroke every 720 degrees of crankshaft rotation. Vibey! Will not rev very high due to heavy components needing to be accelerated very quickly. Throttle response will be relatively dumpy. Cheap! Sound like a huge fart.
Inline side-by-side twin-cylinder (eg GPZ 500, EL500, several middleweight Kawasaki twins, as well as the CB500 and GS500 etc.)
A power stroke every 720/2 degrees of crankshaft rotation. Less vibey. Will rev higher as pistons tend to be smaller, but still plenty of vibes as the pistons move in unison with each other, just 360 degrees out of phase.
90 degree V-twin (eg any Harley, Ducati, SV650, TL, SP1 etc.)
Two cylinders at 90 degrees to each other, both big ends attached to a single crankpin on the crankshaft. The firing interval is uneven, every 270 and 450 degrees of crankshaft rotation. This is why V twin engines sound so nice. Depending on how the engine is arranged in the bike, the vibrations can be pretty bad. This engine is barely balanced at all, and gives quite lumpy torque.
60 degree V-four cylinder engine (eg RVF400, VFR400,750,800, VF500 and Ducati MotoGP bikes amongst others)
The 'V' angle is 60 degrees with two cylinders on each side. The cylinders fire at 720/4 = 180 degree intervals. They tend to sound pretty nice, and since Honda had their camchain tensioner fiasco in the 80's, a lot of them use gear driven cams which add a little more fruitiness. This engine type has poor dynamic balance, so a counterbalance shaft is always necessary. However, it is extremely compact, and can be lightweight. That also makes it a bitch to work on, as the spark plugs and carburettors are a nightmare to access.
Very smooth power output I believe.
In-line four-cylinder engine (Eg almost any large bike and plenty of smaller ones)
Four cylinders in line with each other. The firing interval is 720/4=180 degrees. The engine tends to be very well balanced on its own, all the major moving components cancelling each other out. The number of power impulses provide smooth torque.
As to power and torque, ignoring gas dynamics, it is mostly in the size and shape of the cylinders, especially the bore. You will always get more power out of an engine with components with lower mass. The vibration and smoothness of power output are the most important things. Generally, the more cylinders the better, but things like noise and feel come into play.
Reference: Heinz Heisler, "Vehicle and Engine Technology".
A discussion of combustion chamber shape efficiencies can be forthcoming if needs must. ____________________ I must not be a troll...
Mmmm, Guinness
Discovering the delights of Hammerite and a 3/4" brush.  |
| Kickstart |
| epz |
 epz Scooby Slapper
| mchaggis |
| Kickstart |
 Posted: 17:56 - 27 May 2005 Post subject: |
Basically the more cylinders the more revs, so the more power. So an 8 would be even better. Only reason that hasn't happened really is race rules and costs.
I have this feeling that some Chinese company (with no ties to any racing class) will produce a sports V8 revving to a very high level and producing loads of power as a way of breaking into the sports market.
| epz |
 epz Scooby Slapper
| Kickstart |
| TheShaggyDA |
 TheShaggyDA Repost Police
 Posted: 18:23 - 27 May 2005 Post subject: |
| Kickstart wrote: | However many V twins (such as Harleys) are not 90 degree ones and these vibrate unless you stick a balance shaft on them (which is why the Aprilia Mille has a balance shaft). |
I seem to remember that, maybe in the late 80's or early 90's, that one of the Jap four produced a bike with a 72 degree V twin, so that it would get that sacred Harley "potatopotatopotato" sound, and that HD went to the extreme of attempting to copyright the sound to stop them.
Probably an urban myth. ____________________ Current: CB500 Previous: CB100N, CB250RS, XJ900F, GT550, GPZ750R/1000RX, AJS M16, R100RT, Enfield Bullet
[i:6e3bfc7581]But still I fear and still I dare not laugh at the madman...[/i:6e3bfc7581] |
| Kickstart |
| mchaggis |
 Posted: 18:33 - 27 May 2005 Post subject: |
Extra cylinders needn't mean much extra weight. Because you're keeping the same engine capacity, each cylinder and the internal components get smaller and lighter. I could have sworn I've seen the prototype version of said Chinese V8 superbike  ____________________ I must not be a troll...
Mmmm, Guinness
| stinkwheel |
 Posted: 19:28 - 27 May 2005 Post subject: |
Yep, multi cylinder bikes are definatley faster. They changed the racing rules to stop it because the Japanese manufacturers were getting silly and the race bikes they were building had no relevance to road going machines. Kind of made all the R&D a bit pointless from a commercial point of view.
They were making 5-cylinder 50cc bikes back in the late 60's that would do a genuine 105mph and six cylinder 250 and 350 machines that were doing 100mph laps of the IOM. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| mr.z |
 Posted: 19:35 - 27 May 2005 Post subject: |
Hondas just finished a V5 haven't they?
One is going to be on the new blackbird and theres a race engine V5..
https://vnexpress.net/Vietnam/Oto-Xe-may/2003/12/3B9CDC11/Engine_1B.jpg
There were a few 4cylinder 125s out but are not very rare indeed... gilleras were they? can't remember...
But i still stand by my point that more cylinders = more things to go wrong/wear/maintain... which is ok if you have the money to throw about or can go in a dealership and buy a new bike outright.. ____________________ >RidingSkills<->Tech Tips<->MyBikes<
| epz |
 epz Scooby Slapper
| mr.z |
 Posted: 19:55 - 27 May 2005 Post subject: |
don't forget moto guzzi, they are still twins
because of their slightly lower performance per cc imo twins will probably be religated to cheesy harley reps and budgety type bikes for a while... when i say budget i mean not the cutting edge ultramega sports missiles, more the (relatively) mildly tuned allrounders...
(not includeing the usual exotic twins, i'm talking the major japanese manufacturers) ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| lilredmachine |
 lilredmachine World Chat Champion
 Posted: 19:59 - 27 May 2005 Post subject: |
Aprillia have developed a 550cc v-twin for their supermoto racing bikes. The whole bike weighs 120kg wet. It develops about 80 HP and is already kicking ass. (Look for the red head of the twin in the frame)
Want to know the best thing about it? It appears we are going to get a production version  ____________________ Bikes: too many, too much for one man to maintain anyway. |
| bish777 |
 bish777 World Chat Champion
 Posted: 20:11 - 27 May 2005 Post subject: |
| mchaggis wrote: |
Lightly or Unsilenced 4 stroke singles are the best sounding bikes there are! Ever heard a DR800 with a througher pipe on ? Singles are also compact.
I enjoy fours and the power they give but they just sound like highly strung cars, especially 600's and 400s sound like sewing machines.
| mchaggis wrote: |
An inline (parallel or longitudinal) twin and a V twin can have exaclty the same firing orders, many old twins old twins fire 720 degrees out of phase with pistons in union, but most modern twins have pistons moving up and down relative to eachother firing 360 degrees apart and some have the same firing pattern as a harley Vtwin (270 degrees). Thus a parrallel twin can be made to perform exactly the same as a Vtwin. See the MZ 1000 parallel twin engine for example. ____________________ GSXR1100J |
| Frost |
 Frost World Chat Champion
Thought it was a 450?
They are planning to make a 450 sportsbike, it is likely that they will use and RS250 chassis (why develop a new one when the RS250's is so good!)
Generally the more cylinders, the higher revving, the more power.
V formation engines are known for low down power, so a V4 gives good mid range power due to having multiple cylinders and a V formation. The V5 works on exactly the same principal only honda made it a V5 as the weight limit was the same as that for a V4, so why not have that extra cylinder?
Haiving that extra cylinder, combined with the race tuning is said to give a large amount of power in a usable area towards the top of the rev range.
Manufacturers are currently messing about with firing order and timing to give different performance characteristics.
An old idea was to have a 'Split single' where the bike had 2 cylinders both firing at the same time to give a shorter stroke, and higher rev's whilst retaining the charateristics of a single.
Manufacturers courrently favour a 'big bang' engine which envolves firing 2 of the 4 cylinders at the same time, making the bike behave like a twin with nearly the same power as an in line 4.
My uncle had a bike that was a twin, which sounded exactly like a ducati due to the firing order  |
| Kaben |
 Posted: 21:25 - 27 May 2005 Post subject: |
whoa! alot of that went right over my head, but cheers for the info guys
Am thinking of getting a BMW F650GS, which is a single i believe. Hoping that will be capable of a trip round europe (see my sig for details) and be fairly reliable etc.
Can pick them up for good money (approx 3 grand with alot of the extras and about 10k miles),whereas even poor examples of the 1150GS/adventure are going for ridiculous prices  ____________________ Its Not a Melon, Its Clearly a Lime!!
| Kickstart |
 Posted: 21:36 - 27 May 2005 Post subject: |
| DaFrostyOne wrote: | Thought it was a 450? |
2 versions of the engine are in development, both a 450 and a 550.
| DaFrostyOne wrote: | V formation engines are known for low down power, so a V4 gives good mid range power due to having multiple cylinders and a V formation. |
The V layout will have no effect on that at all.
| DaFrostyOne wrote: | Manufacturers are currently messing about with firing order and timing to give different performance characteristics. |
Not engine performance though. The effect is the way the power goes through the back wheel and how well it grips. Trouble is that such big bang engine give the crankcases and the like a very hard time, so expect failures and / or more weight to compensate by making things stronger.
| DaFrostyOne wrote: | An old idea was to have a 'Split single' where the bike had 2 cylinders both firing at the same time to give a shorter stroke, and higher rev's whilst retaining the charateristics of a single. |
It was played with when the 125GP series switched from twins to singles in the late 1980s.
| bish777 |
| mr.z |
 Posted: 01:25 - 28 May 2005 Post subject: |
If your going to be on the back roads it will be a hoot, and assumeing your not haveing a passenger it should have enough power.. it will do motorway but not comfortably for a long time, if your planing on doing significant motorway sections (like 50% of the time) then maybe look elsewhere imo... unless your not the sort to top 70, in which case it will be ample..
I sold my transalp last week for less than i payed (£1500) that would be perfect for a trundle arround europe.. africa twins go for £2000 or so and are even better..
The 1150gs is nice but you get bikes equaly as capable for allot less. ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
The last post was made 21 years, 105 days ago. Instead of replying here, would creating a new thread be more useful? |
