Adjusting Chain on Bandit *quick reply needed*
JonB
Afraid of Mileage
PostPosted: 09:19 - 28 May 2005    Post subject: Adjusting Chain on Bandit *quick reply needed* Reply with quote
I know it's early on a Sat morning but I am off on a rideout in ummm 20 minutes and I was thinking that I have done 1050 miles and still haven't adjusted the chain tension what I wanna know is: -
A) Is it necessary?
B) If so, how do I go about it. Smile
I know, I know i'm a n00b. Smile
Fruit'n'nut
PostPosted: 09:28 - 28 May 2005    Post subject: Re: Adjusting Chain on Bandit *quick reply needed* Reply with quote
Jon B wrote:
A) Is it necessary?
How much slack movement up and down is there, in the bottom run of the chain? (i.e. the bit in the middle below the swingarm.)
The amount varies from bike to bike*, but if the Bandit is anything like the GSX-R, you should have around 20-35mm of movement, with the rider's weight on the bike.
Check a couple of points, as there will be loose and tight spots.
*Should be somewhere in your handbook/Haynes manual.
Power Ranger Very Happy
JonB
Afraid of Mileage
PostPosted: 09:31 - 28 May 2005    Post subject: Reply with quote
Cheers. Thumbs Up
Fruit'n'nut
PostPosted: 09:37 - 28 May 2005    Post subject: Reply with quote
"How to":
Slacken the rear axle nut ever so slightly. Depending on the bike, there will be some sort of mechanism to move the axle forwards or backwards in the swingarm. On my bike, there's a winder recessed on either side of the swingarm - basically a nut on a thread, along with a locking nut.
Basically, you need to wind the axle forward or backward along the swingarm an equal amount on both sides - there should be some sort of markers on the swingarm. You'll probably only need to move it a tiny amount to slacken/tighten the chain as required.
Be aware that when you tighten all the nuts up, it may affect the chain again slightly - so double-check you have the required amount of slack in the chain. That's why I try to slacken the axle nut and adjusters off as little as possible.
Don't forget to torque your axle up! Thumbs Up Exclamation Thumbs Up
PostPosted: 15:35 - 28 May 2005    Post subject: Reply with quote
Major point to watch for if the 600 is anything like my 1200. When you adjust the chain and get the tension correct, you then do up the wheel spindle. At this point you find that tightening the spindle takes one hell of a lot of slack out of the chain. So basically adjust it slacker than you would think, then tighten the spindle and check, then readjust if necessary.
The last post was made 21 years, 156 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.73 - MySQL Queries: 15 - Page Size: 45.85 Kb
