| LustyLew |
 LustyLew World Chat Champion
 Posted: 20:36 - 30 May 2005 Post subject: Bandit driopping revs and dying |
Hi,
I was riding on the M25 yesterday, everything was going fin until the bike dropped about 500rpm. Then a few hundred yards up the road the power began dropping further. No matter how much I opened the throttle it didn't stabilise. The only thing I noticed was that the sound from the exhaust got louder as the revs dropped.
The bike is a Suzuki Bandit (600cc) on a P plate. The can is not the original, it is a Viper exhaust, I cannot test how it behaves with a normal can, as I don't have one.
anyone have any rough ideas?
I'm thinking either fuel starvation, or flooding of the engine.
Cheers in advance!
Lewis ____________________ Like a Yorkie - I'm not for the girls  |
| lilredmachine |
 lilredmachine World Chat Champion
| LustyLew |
 Posted: 21:59 - 31 May 2005 Post subject: |
Would fitting a dyno jet kit help at all, or just make matters worse? ____________________ Like a Yorkie - I'm not for the girls  |
| Guest |
 Guest Brolly Dolly
| bish777 |
 bish777 World Chat Champion
| bish777 |
| instigator |
 instigator Super Spammer
| LustyLew |
 Posted: 16:55 - 13 Jun 2005 Post subject: |
Right, well I think I've solved it, if I have it set to 'on', it dies. If I have it set to 'res' it's fine.
So that makes it one of two things, error on my part ( ), or the fuel tap is dodgy. Next time I fill up I'll give it a try. ____________________ Like a Yorkie - I'm not for the girls  |
| ZaphodBeeble |
 ZaphodBeeble World Chat Champion
 Posted: 04:25 - 14 Jun 2005 Post subject: |
Check/change the air filter. Check/change the plugs. The way it was dying sounds like a fuel issue. Was it cleanly missing on 1 or more cylinders or was it sort of burbling and missing irregularly? ____________________ Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders. |
| Kickstart |
 Kickstart The Oracle
 Posted: 14:22 - 14 Jun 2005 Post subject: |
Pipe is unlikely to cause the problem, unless it has caused it to run so lean it has suffered engine damage.
It does sound like fuel starvation. Not sure on your Bandit, but I presume it is a vacuum fuel tap. Does it have an "On", "Prime" and "Res" positions, or "On", "Off" and "Res". If it is the 2nd then I would guess that the reserve position is not a vacuum controlled position (prime is normally not vacuum operated, to allow fuel from the carbs to the tank without having the engine running). In which case check the vacuum pipe is in position and not holed, but after that you are probably looking at a failed diaphragm in the fuel tap.
| LustyLew |
 Posted: 23:43 - 15 Jun 2005 Post subject: |
Hi guys,
thanks for all the replies. Much appreciated.
It looks like I've been a complete tit and just underestimated the fuel level in the tank so I was simply running out.
Still better that, than something nasty! ____________________ Like a Yorkie - I'm not for the girls  |
The last post was made 21 years, 123 days ago. Instead of replying here, would creating a new thread be more useful? |
