killa
Won't Shut Up
PostPosted: 12:00 - 08 Jun 2005    Post subject: . 4 Reply with quote
I replaced the front pads on the VFR, the dot 4 level was too high afterwards because of the extra spacing, so I took some out. I took out quite a bit and it is now level with the ‘lower’ mark.
I don’t know, but I think I like the extra pull I get on the lever, but something tells me I shouldn’t have it like that.
Is it dangerous or just personal preference?
mr.z
PostPosted: 12:09 - 08 Jun 2005    Post subject: Reply with quote
It really should be filled to the top.. according to the manual.. but if it stops the bike when you pull the lever where your used to it i can't see theres a problem... dont let it get lower that tht though..
Pad change is a good time to bleed the brakes anyway tbh
cunni
PostPosted: 13:31 - 08 Jun 2005    Post subject: Reply with quote
If even a tiny bit gets lost out of the system when you are travelling, you might let air into it. I'd keep it medium-high if I were you! having no brakes at speed is not clever! Mr. Green
TL1000R Parts For Sale!
killa
Won't Shut Up
PostPosted: 13:40 - 08 Jun 2005    Post subject: Reply with quote
Good point
Embarassed
Hex
Party Boy
PostPosted: 19:07 - 08 Jun 2005    Post subject: Reply with quote
The extra pull is more than likely air, try pumping the lever a few times and does it go hard/not as far in? If so they need bleeding.
Also top the fluid up.. theres a good lad. Wink
The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio
loply
PostPosted: 20:35 - 08 Jun 2005    Post subject: Reply with quote
New pads should lead to less lever travel, surely?
Unless as stated you have air in the system now causing you to compress it all before the brakes do anything.
If the pistons seals are leaking they will gradually seep out some of your fluid so you could end up with none in the resevoir and then you will suck in air everytime you squeeze the lever- Which could lead to the brakes basically not working at all.
Yamaha SZR660 Caution to the wind, the throttle pinned!
The last post was made 21 years, 99 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.51 - MySQL Queries: 13 - Page Size: 49.3 Kb
