my speedo has stoped
bikerboy1
PostPosted: 14:45 - 17 Dec 2002    Post subject: my speedo has stoped Reply with quote
it an't moving and the mileage don't move too, whats wrong with the cunt. do u think it's just stuck?
when you see something like a bullet going past you, don't worry it's only me!!!!
Scotty
Scooter Boi
PostPosted: 14:48 - 17 Dec 2002    Post subject: Reply with quote
Check the lead / cable hasnt come out the speedo or wheel hub.
Also check the cable hasnt snapped.
Ive gone through this a few times befroe on other posts.
Maybe someone could refere you to an old post.
Regards
Scott
Robby
Dirty Old Man
PostPosted: 14:51 - 17 Dec 2002    Post subject: Reply with quote
its one of 3 things:
speedo drive.
this is where the speedo cable links to the front wheel hub, they have been know to go. if it has you need to get a new one, try breakers.
speedo cable.
to check this undo the cable from the drive and speedo and turn the central core around. if it spins at the other end your speedo is ok.
speedo unit.
well if this is gone its expensive. ask you local bike shop, or an aprilia specialsist, if they can repair them. if not its new speedo or breakers speedo, although they will be one of the first things to go in an accident.
when my speedo stopped working, the cable had just dropped out the bottom of the speedo from vibration, so check that first.
PostPosted: 16:56 - 17 Dec 2002    Post subject: Reply with quote
Check the cable first as they are cheap enough to do. However the speedo drive (on the front wheel spindle) on the later RS125 does seem to be known for failing
All thebest
bikerboy1
PostPosted: 17:36 - 17 Dec 2002    Post subject: Reply with quote
i got the 97-98 model kickstart!! i have checked the cable and it was loose a little but i fixed it but it still don't work!! i will undo it and do it up again then take it for a good run and see what happens!!!!
keep the help cuming everyone!!!!!!!!!! Laughing Very Happy Very Happy
Annabella
Like a person, only smaller
PostPosted: 23:11 - 17 Dec 2002    Post subject: Reply with quote
Do a search.
There is a post somewhere about replacing a speedo cable. It has probably snapped. Check this by undoing it, spin the front wheel, and feel the end to check it's rotating. If it isn't then the cable has snapped.
Avast! Pirates ahoy!
I did Cadwell! Very Happy
retrofly
PostPosted: 00:22 - 18 Dec 2002    Post subject: Reply with quote
hi
on mine the wheel bearings had snapped and broke the speedo thing in the wheel
Luke
"The food was not undelicious"
-Homer Simpson (Exceptional beast : Underachiving Human)
www.geocities.com/retrofly
Scotty
Scooter Boi
PostPosted: 11:30 - 18 Dec 2002    Post subject: Reply with quote
same as me retro, it sucks but hey what you gonna do!
Regards
Scott
TiN
Pocket Tin
PostPosted: 13:09 - 18 Dec 2002    Post subject: Reply with quote
"fixed it"? you mean secured it? did you do what Robby suggested? - un-screw the cable from your speedo, and roll the bike forwards and backwards, and see if the metal core rotates - if so, then the cable is fine and it's probably one of the other things that Robby suggested.
TiN
dotgems.net
bikerboy1
PostPosted: 10:50 - 19 Dec 2002    Post subject: Reply with quote
i am going to check today!! i just hope it's loose.
The last post was made 23 years, 307 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.82 - MySQL Queries: 15 - Page Size: 63.95 Kb
