power on, power off, power on, power dies!
graeme
PostPosted: 23:18 - 08 Jun 2005    Post subject: power on, power off, power on, power dies! Reply with quote
i rod emy scooter back from my mates, which is about 12 mile. as i got to by my house, i stopped to go on to the path an as i went to put throttle back on, it just bogged down and died.
its still walm an i try start it and it wont work, but if i put the choke on it will. then when i take the choke off, it bogs down agen when i rev it on it dies.
its a malossi big bore carb and it has a manual choke
someone have a clue what it could be??
thanx
g.macdonald
kingsknight
PostPosted: 23:20 - 08 Jun 2005    Post subject: Reply with quote
once you sort your problem out mate sell the thing and get a different bike mate you have had a lot of problems with it.
Sounds to me like your crab needs a good clean and tuning
TS50 (sold) NS125F (sold) NSR125R-K (write off after 2 crashes) CG125 (nicked) XR125L-3 (Sold )-: ) DR125SM '11 (sold yay) XL125V '12 (In love with this bike) XT600E '04 (fun on the dirt)
graeme
PostPosted: 23:37 - 08 Jun 2005    Post subject: Reply with quote
excuse me, but right now the last thing i want is people sayin that i should just get rid of it, i just want it sorting first
someone said it might be the air? petrol mixture? too much air
g.macdonald
kingsknight
PostPosted: 23:42 - 08 Jun 2005    Post subject: Reply with quote
not enough air it sounds like as it dies once you take the choke off.
Putting your choke on allows more air into your carb.
Play around with your carb but be careful not to make your ped run lean
mr jamez
PostPosted: 23:49 - 08 Jun 2005    Post subject: Re: scooter dies again. seems like it is flooding?? Reply with quote
So does it have a big bore kit on the bike or just a larger carb? if it is a big bore have you changed the jetting? or of it is just a different carb, put the original one on and use the factory standard settings.
Doesn't sound like it is flooding as it runs OK when you are manipulating the choke (which is enriching the mixture)
Is the air filter clean? if it is a two stroke put a new spark plug in it.
I had a similar problem on my NSR, turned out the cylinder wall was cracked, so low compression and would only run with the choke on.
Josh|RD125LC
PostPosted: 23:51 - 08 Jun 2005    Post subject: Reply with quote
Maybe its jetted up wrong? You may have a too big jet, check the size and make sure its the standard size. Unless you have performance mods.
Honda MBX50 | Yamaha RD125LC | Suzuki RG125F Lucky Strike | Suzuki GSF600S
RD125LC Pictures
graeme
PostPosted: 12:28 - 09 Jun 2005    Post subject: Reply with quote
right, its got something like a 63cc barrel kit on it now with the malossi big bore carb on, its been jetted right for that kit ( he said he put a slightly bigger than the recommended one in because i go moraless flat out)
the mechanic who fixed it said there might be some crap in the carp, by the jetting or something, so i just taken the float bowl off, cleaned inside it, removed the pilot jet, blew inside that, put it back together an it ticked over fine
im just wondering if i might need to do something else before it breaks again
thanx
g.macdonald
divuk83
PostPosted: 14:32 - 09 Jun 2005    Post subject: Reply with quote
What does the plug look like, as if he put a bigger jet than it needs in it will be fouling the plugs much faster.
Dave
mchaggis
PostPosted: 20:59 - 09 Jun 2005    Post subject: Reply with quote
You what? Eh?
Choking the carburettor increases the venturi effect, lowering the air pressure, so sucks through more fuel.
Agreed with the clean at any rate.
I should really read the whole thread before I reply. Smile
I must not be a troll...
Mmmm, Guinness
graeme
PostPosted: 02:22 - 11 Jun 2005    Post subject: Reply with quote
the problems getting better, i just have to take the carb apart each day an clean the jettin then its ok for a few more hours Confused
but now, when im riding along, i put the throttle on from the start an the power is there, but when im goin along about 20 - 40 and let the throttle off then back on, it like dies down an i hav to go like full throttle to get any power, why???
thanx
g.macdonald
BFG
PostPosted: 20:11 - 15 Jun 2005    Post subject: Reply with quote
Sounds like there's crap in the fuel tank. Fit a fuel filter and see if that helps.
The last post was made 21 years, 125 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.98 - MySQL Queries: 15 - Page Size: 70.67 Kb
