where is my oil going?
White Noise
Mr Dudwee
PostPosted: 14:29 - 12 Jun 2005    Post subject: where is my oil going? Reply with quote
it seems as of latetly my bike has been drinking oil and i don't know why!
for example about 300 miles ago i filled the oil upto the top level of the sight glass, then this morning on a short ride i was surpried to see the oil level waning light come on. i got home and checked the sight glass and yes indeed it was around the lower level of the sight glass. so i am puzzled about where the oil is going! i have noticed small deposits of a oily substance just below the head gasket of the left most cylinder but don't think this can account for the amount of oil i have been loosing. i have noitice a large collection of oil around some rubber pipes just behind the engine but not sure if its from a oil overflow of some sort or the chain, so i am guessing that i am burning oil, which i think is pretty bad! what is the implications of this? and what do i need to do to stop it?
the bike is a 96' divvy 600. thanks for advice given Thumbs Up
WN
PostPosted: 14:52 - 12 Jun 2005    Post subject: Reply with quote
I reckon you need to do a compression test for starters. Check the compression on each pot then put a few drops of oil down the sparkplug holes and turn the bike over a couple of times. Now check the compression again, if the reading is significantly higher it is time to tear the top-end down and check it out (vlave-stem oil seals, ring wear, bore wear etc).
Also check the base gasket isn't leaking, they can blow oil out in damned funny ways. A mate of mine had a bike that was using oil. There was a smear of oil along the outside of one of his panniers. Turned out it was coming from the base gasket.
Gunk your engine so it is nice and clean, then any leaks should show up clearly.
bish777
PostPosted: 15:02 - 12 Jun 2005    Post subject: Reply with quote
go to the MSN groups Divvy club as this is a known problem on 96-on divvy 600s. A faulty seal design pumps oil out of a breather.
https://groups.msn.com/YamahaDiversions/techinfo.msnw?action=get_message&mview=0&ID_Message=16&LastModified=4675470798008058682
GSXR1100J
Gazdaman
I did a trackday!!!
PostPosted: 18:40 - 12 Jun 2005    Post subject: Reply with quote
I've got a faulty oil light! It can be full on the glass, but the light will still come on.
And yes I know it's really a pressure light, but it's damn picky!
My head and base gaskets seep ever so slightly.
Gaz
bish777
PostPosted: 19:10 - 12 Jun 2005    Post subject: Reply with quote
most engines weep a little once theyve aged a bit. Invest in a torque wrench and retorque the head. Solved such minor weeps on my GSXR.
GSXR1100J
Method
PostPosted: 11:56 - 13 Jun 2005    Post subject: Reply with quote
My GS500 is a '94 model and also drinks a lot of oil, it comes with age.
Although i think mine is spouting most of it out the bloody gear change... as when i look down i can see a large patch of black shiney stuff on my shoe. And when i park up i have to put a leaf or something by my sidestand, otherwise when i return there is a nice warm patch of blackness there waiting for me ...
At least you can tell where "My Parking Space" in the college compound is now though Embarassed
CBT Aug '03 ... Gilera GSM 50 ... Honda NSR 125 Aug '04 ...
Full Test Dec 04... Suzuki GS500 Jan 05... Suzuki SV650 Mar 07... Gixxer 6 K5 May 08... Oh and my 'Rado Wink
My Bikepics.com - No Brakes, No Gears... No Fear.
bish777
PostPosted: 16:30 - 13 Jun 2005    Post subject: Reply with quote
I also retorqued everything torqueable, invested in new cam cover gaskets, and used instant gasket on the side covers. Maek sure to put a new crush washer on the sump plug when you change the oil next.
GSXR1100J
BFG
PostPosted: 20:31 - 15 Jun 2005    Post subject: Re: where is my oil going? Reply with quote
White Noise wrote:
iso i am guessing that i am burning oil, which i think is pretty bad!
Any smoke coming from the exhausts?
White Noise
Mr Dudwee
PostPosted: 20:37 - 15 Jun 2005    Post subject: Reply with quote
nope, noticed today at work that oil had appeared from below the breather pipes, think it maybe a blocked breather pipe/pattern oil filter or something similar, still trying to get to the bottom of it!
WN
The last post was made 21 years, 125 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 62.39 Kb
