nsr headlight adjustment
hutchy
PostPosted: 11:56 - 13 Jun 2005    Post subject: nsr headlight adjustment Reply with quote
Hi guys my 01 nsr failed its mot on saturday as the dip beam was too high, how do I adjust it and any tips for testing out its height?
the tester said the beam should be 3"3 when the bike faces a wall
thanks
Method
PostPosted: 12:04 - 13 Jun 2005    Post subject: Reply with quote
Right im not 100% sure on this but...
Most sealed headlight units (like the NSR) will have a screw type fitting on the top, sometimes in the form of a srew, sometimes in the form of a alan key bolt. Putting a screw driver / alan key on this fitting, and rotating it in one direction will either raise / lower the beam.
The way i check is to wait till dark, move my bike to about 5meters away from a flat wall, and turn the lights on, go to the wall, and draw a line where my waist is, then adjust my lights to be just around that line... that to me is near enough the legal requirements and has seen me through 2 MoT's. Although i got a feeling i may have a problem with my next MoT... damn bike Wink
But im not 100% sure about the NSR adjustment... so maybe someone else can confirm / slate that idea? Laughing
CBT Aug '03 ... Gilera GSM 50 ... Honda NSR 125 Aug '04 ...
Full Test Dec 04... Suzuki GS500 Jan 05... Suzuki SV650 Mar 07... Gixxer 6 K5 May 08... Oh and my 'Rado Wink
My Bikepics.com - No Brakes, No Gears... No Fear.
Method
PostPosted: 12:06 - 13 Jun 2005    Post subject: Reply with quote
Might want to check this out
https://www.bikechatforums.com/viewtopic.php?t=41567&postdays=0&postorder=asc&start=0
There is a NSR manual listed there, i would download and check it out for you but at 63meg i cant be bothered to wait lol
Hope thats of some use to you Thumbs Up
alains
PostPosted: 12:56 - 13 Jun 2005    Post subject: Reply with quote
look at the picture
hutchy
PostPosted: 21:55 - 13 Jun 2005    Post subject: Reply with quote
from memory that looks nothing like my headlight and if thats the case i definately will not be able to do it unless the unit is off the bike Sad
alains
PostPosted: 22:04 - 13 Jun 2005    Post subject: Reply with quote
otherwise you can insert washers on top 2 fixing
alains
PostPosted: 22:26 - 13 Jun 2005    Post subject: Reply with quote
i said stupid thing ; insert washers on the bottom ! sorry
hutchy
PostPosted: 01:30 - 14 Jun 2005    Post subject: Reply with quote
would putting washers in the bottom two not make the headlight point higher though? I need lower?
think I'll just have a look myself tomorow
Method
PostPosted: 13:06 - 14 Jun 2005    Post subject: Reply with quote
That does look like the unit i had on my bike mate...
Its just hidden behind the fairing... remove the fairing and you should be able to get at the light unit, POP Thumbs Up
hutchy
PostPosted: 00:51 - 15 Jun 2005    Post subject: Reply with quote
yeh I've had a look, means I'm going to have to take the unit off the bike to do it what a pain in the arse. Do I need to turn each screw by the same number of turns, does each bolt adjust an individual light?
alains
PostPosted: 13:10 - 15 Jun 2005    Post subject: Reply with quote
put your bike about 3-4 yards in front of a wall on a flat surface , put somebody on the seat . make a mark on the wall where the lights meet . then move the adjusters , and you will see the spot on the wall moving . thightening the lower screw will move the headlight up but also right . thightening the upper screw will do the reverse . i will definitly go for inserting 2 or 3 washers at the 2 lower fixing , this will move the site without moving azimuth
The last post was made 21 years, 126 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.67 - MySQL Queries: 13 - Page Size: 69.24 Kb
