| Robson |
 Robson Scooby Slapper
 Posted: 14:37 - 18 Dec 2002 Post subject: Anyone like V8's |
Anyone like V8's...............and no were not talking cars here
goto www.22000rpm.com and check out the monsters in theyre made by drysdale and theres a sound clip of a 750 V8 what a sound youve gota check it out
https://home.mira.net/~iwd/av/drysdale750v8.mp3 ____________________ Cheers
Paul (Robson) |
| Milo |
 Milo World Chat Champion
 Posted: 14:39 - 18 Dec 2002 Post subject: |
Yeah, i've seen them in MCN before, it must sound good. but my work comp doesn't have speakers  |
| Robson |
| Kickstart |
 Kickstart The Oracle
| craigT19 |
 craigT19 Jolly Green Giant
 Posted: 20:16 - 19 Dec 2002 Post subject: |
hmmmm V8 bikes are yet to make a big imprssion on me....granted they sound nice...but to me they just look "clumsey" im not shur if they would handle very well??? ____________________ Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
BCF member pops. sadly missed 1945-2003 |
| Doddmaster |
 Doddmaster World Chat Champion
| G |
 G The Voice of Reason
| Robson |
 Posted: 10:17 - 20 Dec 2002 Post subject: |
These bikes are supposedly going to be entered into motogp if they get enoyugh funding i can assure you they are no cruisers the engines will only be 30mm wider than a NSR500 gp bike make sh*loads more power and scream out to 22,000rpm what more do you want i'd have one of these over any NSR500 or the new V5's, here are the specs in comparison to the NSR500 GP bike
Drysdale 990-V8 NSR 500
990cc V8 - 4 stroke 500cc V4 - 2 stroke
Cylinders 8 4
Redline 20,600rpm 14,000rpm
Power 165kW (220hp) 140kW (185hp)
Mass (no fuel) 155kg 135kg
Race Weight 175kg 162kg
Power to Weight Ratio 0.942 0.864
Fuel 24 litres 32 litres
Engine width 330mm ~ 300mm
Engine mass 52kg 45kg
Top Speed 360kph 340kph
1. Better power to weight - With a full fuel load at the beginning of the race the Drysdale 990-V8 will be only 13 kg heavier than the benchmark NSR 500 Honda. With a superior power to weight ratio and little more in frontal area - the 990-V8 will be faster in a straight line and should give away very little in the corners.
2. Better turn-in- The single heaviest component in any modern race motor is the crankshaft - the 990ccV8 crankshaft will weigh only 4.3 kg - significantly less than the complex pressed-up roller-bearing item used in the Honda NSR 500. This represents a major reduction in the rotating mass which reduces gyroscopic forces and allows the whole motorcycle to be much easier to tip into a corner or turn generally.
3. More Power- The engine revs and power stated above are quite conservative - with ongoing development it is not unreasonable to expect 22,000 rpm and 180kW (240 hp) from a short stroke 990cc V8.
https://www.22000rpm.com/images/introimage550.jpg ____________________ Cheers
Paul (Robson) |
| Milo |
 Posted: 11:29 - 20 Dec 2002 Post subject: |
think about this one...
2 pipes down each side and 4 under the seat  |
| Robson |
| Keith |
 Keith Guest
| Milo |
 Posted: 14:28 - 20 Dec 2002 Post subject: |
that'd be quite funny, but it'd have to be geared to about 400mph for anyone to be able to hold on!  |
| Robby |
 Robby Dirty Old Man
| G |
 Posted: 15:00 - 20 Dec 2002 Post subject: |
I think they're not tuning any of teh motogp bikes much past 220hp, because they can't do anything with it.
Anyone got a couple of NSR engines lying around?.. we could weld them together and wee what happens  |
| Robson |
 Posted: 15:06 - 20 Dec 2002 Post subject: |
yeh i know what your saying theyres only so much usefull power you can put on the rubber before it becomes unusable.....i just wanna hear these babys scream past 21,000rpm  ____________________ Cheers
Paul (Robson) |
| G |
 Posted: 15:51 - 20 Dec 2002 Post subject: |
There's also only so much accelration a certain wheel base can have without the front lifting. Increase the wheelbase and steering suffers  |
| Robson |
| Robby |
 Robby Dirty Old Man
| Robson |
| G |
| Robby |
 Robby Dirty Old Man
| Keith |
 Keith Guest
| Robby |
 Robby Dirty Old Man
| Kickstart |
 Posted: 13:21 - 21 Dec 2002 Post subject: |
No, a viscous coupling allows some torque to be transmitted. Basically you have one shaft in and one out, but the 2 are not directly connected. Each shaft is connected to a load of disks, with the disk alternating. In the unit there is a fluid which gets more viscous as it warms up. When both the input and output shafts are turning at the same speed (so when it is in the drive to the rear wheels, both the front wheels and the rear wheels are turning at the same speed) all the disks are turning at the same speed, and very little heat is generated. As the front wheels start to slip, the input shaft starts to turn more quickly than the output shaft, so the speed of the disks varies and the fluid is warmed up. As it warms up it thickens, and starts to bind the disks together, transferring more torque to the output shaft (and so the rear wheels)
They are used where you need to allow some difference in speed between one side and the other, but need to limit that diffrerence
All thebest
The last post was made 23 years, 296 days ago. Instead of replying here, would creating a new thread be more useful? |
