catalytic exhaust.changed subject look
-Ali-
PostPosted: 12:58 - 15 Jun 2005    Post subject: catalytic exhaust.changed subject look Reply with quote
hi, my zip has a catalytic exhaust but if i replace it with a derestricted non catalytic exhaust will it be alright, as the reacing exhaust don't use a catalyst n work so would i just put it on a up jet the carb like a norm exhaust.
also will the exhaust from a typhoon fit my zip. its a 51 zip
https://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=25640&item=7979994590&rd=1
that is the typhoon exhaust
PostPosted: 13:26 - 15 Jun 2005    Post subject: Reply with quote
You probably will need to play around with the jetting just from going for a different exhaust. However it might well run a touch richer than it needs to get the cat to work.
Dumping the cat should not cause any real problems (beyond a load of extra pollution).
Kye
PostPosted: 16:23 - 15 Jun 2005    Post subject: Reply with quote
Go up to a 60 main jet, but you might as well just buy a race pipe like a Gianelli or a Hebo, since swapping to a non cat exhuast makes fuck all difference, even just cutting the little pipe on the normal ones doesn't make much/any difference. We've tried all sorts in the workshop and the best 2 reasonably priced for performance pipes we've found are the Gianelli Reverse and the Hebo nickel plated.
Ducati 600SS
Vespa PX125
-Ali-
PostPosted: 17:38 - 15 Jun 2005    Post subject: Reply with quote
kye, i don't want a racing exhasut because i only have a couple on months left till i'm 17 so going to upgrade, so there's no point fiddling with the exhaust, so shall i just take the washer out and leave it
The last post was made 21 years, 126 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 40.34 Kb
