Fireblade leaky carb-engine joint
black gpz500s
PostPosted: 20:41 - 16 Jun 2005    Post subject: Fireblade leaky carb-engine joint Reply with quote
Just noticed a very slight weeping of fuel / oil from the carburettor to engine block joint on my leftmost carb.
Is it anything to worry about? Performance isn't down, and the bike may have been like this all the time I've had it.
The hose clip screw holding the carb onto the engine block is accessible thru the fairing. Should I try tightening this ?
(Note there is no weeping from the other carbs)
DM
PostPosted: 22:12 - 17 Jun 2005    Post subject: Reply with quote
My guess is the other carb was teasing it Crying or Very sad.
But seriously, any leaking at that point can cause a slight leaning of the mixture and lower performance/raise engine temperature, but since you haven't noticed any differences yet then it's probably quite minor. Regardless, you should definitely tighten the clamp when you next have the chance and get that leak stopped.
proximity
PostPosted: 22:46 - 17 Jun 2005    Post subject: Reply with quote
If its too bad it could set on fire?
2004 Aprilia Tuono
The last post was made 21 years, 157 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 34.67 Kb
