tank slapper!
matphillipsuk
PostPosted: 13:06 - 17 Jun 2005    Post subject: tank slapper! Reply with quote
i have noticed that when i let go of the bars above about 25mph they start trying to brake my thumbs even if i still have one hand on the bars. any idea what this could be? i can never remember it doing it before .ive just had the fork seals replaced on my nsr could this have any relation to it?cheers for any help
PostPosted: 13:17 - 17 Jun 2005    Post subject: Re: tank slapper! Reply with quote
It may be suspension is now doing something it /should/ be!
My RS250 starts to shake a bit if you take your hands off the bars; but I think that's a consequence of it being very nimble steering.
Plenty of other things can effect it, like head bearings, attitude, etc, etc.
matphillipsuk
PostPosted: 13:21 - 17 Jun 2005    Post subject: Reply with quote
ok thanks cheers
BlackSheep
PostPosted: 00:37 - 18 Jun 2005    Post subject: Reply with quote
Check your head bearings , your front tyre pressure , and get a mate to sit on the bike and hold the bars tight while you grab your front wheel at the 12 and 6 o clock position and wobble it to check for play in your wheel bearings , repeat at the 3 and 9 o clock position there should be NO play
it might be a good idea to check tighten your wheel spindle and fork yoke bolts too as you have recently had some frond end work done they may have left something a little loose.
GSXR 1100 StreetFighter
matphillipsuk
PostPosted: 10:27 - 20 Jun 2005    Post subject: Reply with quote
ok cheers
Chr!S
PostPosted: 11:33 - 20 Jun 2005    Post subject: Reply with quote
Wheel balence too.
Blueknyt
PostPosted: 05:08 - 21 Jun 2005    Post subject: Reply with quote
underinflated tires front,rear/both, Missaligned wheels (mainly rear in relation to front) warped/bent or worn swingarm/bushings, wheel bearings (front or rear) unseated tire,bent rim, spring preload/airpressure in forks differnt from left to right, bent fork brace, LACK of a fork brace, improper fork oil level (mainly one side near empty while other full) bent or tweeked frame/forks/triple tree.
while ive gotten pleny of vibration from unballenced wheels, ive never had a wobble from lack of ballencing, i rotate wheels on my GS500 and katana 600 as they are the same (baring rotors/spacers for given bike) when i tire wears out on one, i swap with a spare and put another tire on that rim and its ready for which ever bike needs it next, never ballenced a single one.
the most common wobble causes for my bikes was:
improper wheel alignment (those tick marks on swingarm suck)
Improper tire pressure, (low most the time)
or worn out stearing stem bearings(wheelies and stoppies do hurt)
The last post was made 21 years, 153 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.23 - MySQL Queries: 13 - Page Size: 51.53 Kb
