Honda CLR 125 help please
Mark_petty
PostPosted: 07:19 - 18 Jun 2005    Post subject: Honda CLR 125 help please Reply with quote
When I try to start my bike it seems to make a tick noise from the battery area and not fire up, it doesn't seem to even try it just makes a tick/click sort of noise.
Would this mean the battery is low?
Thanks
PostPosted: 09:41 - 18 Jun 2005    Post subject: Re: Honda CLR 125 help please Reply with quote
Battery low would be the first thing I'd try to rectify.
Definitely in neutral?
Will it bump start if checking/sorting the above doesn't help?
If so it may be a dodgy connection for a neutral sensor or similar.
Try pulling the clutch in while you press the starter.
Mark_petty
PostPosted: 12:55 - 18 Jun 2005    Post subject: Re: Honda CLR 125 help please Reply with quote
Cheers I will check the battery first.
The neutral light is on, but I will pull the clutch in to see if that helps.
Thanks
The last post was made 21 years, 156 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 1.34 - MySQL Queries: 13 - Page Size: 35.37 Kb
