| bikerg |
 bikerg Borekit Bruiser
 Posted: 20:00 - 16 Jun 2005 Post subject: TZR fuel problem? |
Hi,
My TZR 125 is still giving me hassle.
It does around 55 miles on £5 ~ 6 litres, and maths says thats 40 mpg ish.
Is this at all normal?
I have put on a new fuel filter (it is on the right way round), and new fuel line as I was worried about it leaking from connections, still no change.
6th gear gives me hassle too, I don't seem to get any power at all, the bike just slows down when i change up, even at 8-9k rpms. I also get spluttering at 9.5k rpms in every gear, I have cleaned the carb several times before.
Any ideas?
Thanks! |
| imadoofus |
 imadoofus Renault 5 Driver
| bikerg |
 Posted: 23:13 - 16 Jun 2005 Post subject: |
I don't know about jets to be honest, my workshop manual just tells me settings shouldn't need to be changed.
Spark is fine, nice and bright blue. Recently had trouble with a dud spark, but put a high performance NGK in and it seems ok.
Also, if I ride for 5-10 mins at 8-9k rpms then drop then throttle approaching a village etc. When I hit the throttle again, it acts as if there is no petrol, then it slowly picks up (while spluttering) then its fine...
Seriously confused |
| Bomberman |
 Bomberman World Chat Champion
 Posted: 18:22 - 17 Jun 2005 Post subject: |
Has it got the full powervalve dealy fitted? Or are you just running derestricted with it open? What spark have you put in it now?
Anyway, 55 miles for £5 is poor. Mine gets 100 miles for ~£7. ____________________ 'Allo! My name is Inigo Montoya, you killed my father, prepare to die!
'89 TZR 125 - '94 GPZ500s - ZK3 GSXR600 Alstare  |
| bikerg |
| Bomberman |
 Posted: 21:11 - 17 Jun 2005 Post subject: |
Hmm, bit of a longshot, but put a BR9ES in instead. That's te recommended spark (and the one I've always used), but the handbook does say that a BR8ES should be OK. But something to try for about £3 eh? Also, is the powervavle working OK? Not getting stuck or its cables sticking? ____________________ 'Allo! My name is Inigo Montoya, you killed my father, prepare to die!
| bikerg |
 Posted: 16:54 - 19 Jun 2005 Post subject: |
Powervalve seems ok, although it looks like its leaking...  |
| Gazdaman |
 Gazdaman I did a trackday!!!
| simon1221 |
 simon1221 World Chat Champion
| bikerg |
 Posted: 08:51 - 20 Jun 2005 Post subject: |
The powervalve goes through its full cycle, I can hear it turn twice. If I start the bike, then switch off then on, it turns three times.
I'm not sure what the "oil" is, there is a thin black liquid which is sprayed on the inside of my fairing and down the left side of the engine, it seems to come from 2 holes in the powervavle thingy on the left of the engine (with the cables coming out of it).
I used to use a BR9ES, but the bike died with it, changed to my current spark and it started fine, I've lost my trust in the 9.
Is it worth switching the fuel tap off at night? Where does fuel leak from? |
 Posted: 12:05 - 20 Jun 2005 Post subject: |
An 8 plug will run hotter than a 9. The 9 is more likely to foul up round town, etc, while the 8 is more likely to run too hot, blister and fail (possibly damaging the piston at the same time). However on a 2 stroke the spark plug is a consumable, and unlikely to really be worth trusting for more than 1000~2000 miles.
The "oil" coming out from around the power valve is probably the same stuff that you get dribbling out of the end of the silencer. Basically a mix of burnt and unburnt petrol and 2 stroke oil.
The reason you should turn the petrol off is that if the needle valve in the carb is not sealing correctly then it will allow fuel past. With the petrol turned on it has a nice large reservior of fuel to allow past. This fuel might come out of the car overflow and onto the floor, or it might overflow into the engine. I left my 1200 Bandit on prime one night (bypasses the vacuum operated tap that is fitted) without noticing, and by the following morning it had emptied over 10L of petrol through the carbs and into the engine and airbox.
| bikerg |
 Posted: 00:58 - 23 Jun 2005 Post subject: |
Ok, did some work on my TZR today.
Took out the spark plug, the BR8ES. It has oil around the edge (by the screw), and some strange carbon/oil looking chunks on it too. The electrodes are a tan/brown colour, with the top electrode covered in oil at the base. The ceramic is brown, it looks like parts are flaking off slowly...
I'm still not sure about the oil, I have attached a photo, showing where the oil is, there is no oil on the other side of the bike! There are "drain?" holes in the bottom of the powervalve control housing thingy, and when I take the cover off, it is covered on the inside in the black oil... |
The last post was made 21 years, 129 days ago. Instead of replying here, would creating a new thread be more useful? |
