| Craggles |
 Craggles Traffic Copper
 Posted: 10:39 - 24 Jun 2005 Post subject: How does the Hot Weather affect your bike? (Fuel System) |
Hiya,
Recently I've had a couple of problems with the bike.
It started a few days ago - as I pull the clutch in, the revs just die away. This is completley random - happened about 3 times so far though so it's not just me stalling it (I fail to believe I've lost all sense of clutch control in a matter of a few days, yet am still able to change gear smooth as ever!).
I've also noticed, whilst travelling at speeds which require constant power (80 - 90mph) the power seems to drop off and come back. A little like if I was running low on fuel, just less so.
Yesterday, following a lorry, the bike started to seriously splutter and jump as if the tank was empty. "Odd" I thought - I would not usually even think of filling up for another 10 miles. Anyway, I pull into a layby and the engine just dies as soon as I pull in the clutch.
Switch to reserve, try starting again. No Luck. "Bugger" I think. So faf around for a few minutes, switch fuel off, on, reserve. Leave it etc... Checked the tank - it was low but still had fuel! Try again... No luck. By this time, a friend had stopped - he suggested I open the tank and then try starting. So I do, and as if by magic, it starts!
So we head home. Speaking to some friends, they also seem to be having problems like this with their cars - they put it down to the hot weather and fuel evaporation...
Could this cause problems like this, or should I be looking deeper?
I'm wondering if the air filter could have become gummed up with flies - considering the state my headlamp and helmet after weds! Cleaned the bike on friday too!
Craig[/code] ____________________ If this signature is blue, you're riding too fast |
| king756 |
 king756 Nitrous Nuisance
| paulthewitt |
 paulthewitt World Chat Champion
| craigs23 |
 craigs23 Mr Muscle
| Craggles |
| Dom_ |
 Dom_ Points Mean Prizes
| Kickstart |
 Kickstart The Oracle
 Posted: 12:10 - 24 Jun 2005 Post subject: |
Hot weather can cause fuel vapourisation issues. Normally this would cause a problem with warm starts (unless you are unlucky enough to get a vapour lock in a fuel line), basically because there will be a load of fuel vapour in the carbs / airbox / etc causing it to be very rich.
However the heat also causes issues with the mixture. You are getting far less mass of air into the engine for the same volume which should richen the mixture up. If the bike is already fairly rich then this might well cause problems.
Also you noticeably loose power in hot weather. Last years Big CC dyno day was a very hot day. Everyone seemed to be about 5% down on the expected levels of power (eg, my Bandit made 145hp, where it had made 153 only about a month before at the same place). Now 5% is not likely to be noticeable in normal riding (quite noticeable if you have measuring equipment, or try a top speed run), but might well cause the idle speed to drop enough to cause problems.
A fuel injected car really should not suffer problems like this though (the fuel is under serious pressure and flowing rapidly so should not vapourise, plus the car can adjust the mixture with the readings from the lambda probe, plus most fuel injection systems will measure the mass of air, rather than a CV carb that will meter the fuel based on the volume of air).
| danclarkie |
 danclarkie Scooby Slapper
i suffer exactly the same problems on my TW spluttering along sometimes and after i was riding it full throttle in 5th for about 10 mins it started splutterng as if out of fuel so i pulled over dropped the clutch and the engine just cut out. que 10 minutes of faffing around with spark plug fuel tap ect, being about 6 miles from home without my mobile on a fast A road with no hard shoulder or pavement, i had to hike my bike off the road onto the field next to it, started after i changed the plug at the roadside. only time its occoured recently is when im high up in the revs the bike will sometimes sort of judder as if its not sparking, then i change up the gears and its fine  ____________________ Bah Humbug |
| Kram |
 Kram World Chat Champion
| Method |
 Method World Chat Champion
 Posted: 13:18 - 24 Jun 2005 Post subject: Re: How does the Hot Weather affect your bike? (Fuel System) |
| Craggles wrote: | Hiya,
That is the exact same problem that i had with my GS500 mate... in this thread https://www.bikechatforums.com/viewtopic.php?t=52600 ____________________ CBT Aug '03 ... Gilera GSM 50 ... Honda NSR 125 Aug '04 ...
Full Test Dec 04... Suzuki GS500 Jan 05... Suzuki SV650 Mar 07... Gixxer 6 K5 May 08... Oh and my 'Rado
My Bikepics.com - No Brakes, No Gears... No Fear. |
| craigs23 |
 craigs23 Mr Muscle
 Posted: 14:07 - 24 Jun 2005 Post subject: |
So is the soloution to fuel vapouration to run a slightly leaner engine with smaller sized jets? (or a free'er flowing can? ) |
| Courageous T |
 Courageous T Scooby Slapper
| Kickstart |
The last post was made 21 years, 104 days ago. Instead of replying here, would creating a new thread be more useful? |
