Ash T and Dom_'s Potentially Fatal Experience.....Dustcaps
ash t
PostPosted: 22:19 - 26 Jun 2005    Post subject: Ash T and Dom_'s Potentially Fatal Experience.....Dustcaps Reply with quote
yes, it could have been fatal i suppose..
If you have Dustcaps that are not standard, get rid of them.
Me and Dom_ went to see some friends in derby tonight, and because of an Anodised dustcap (we think) the front tyre COMPLETELY DEFLATED. To think we were doing the speed we were on a flat tyre. I didnt notice until the steering felt really heavy and unstable on a roundabout.
GET RID OF THOSE ORRIBLE THINGS!
When You're Starting To Choke, Take Some Pills With Your Coke, Its Hyserical
Jrod
Page 3 Girl
PostPosted: 22:22 - 26 Jun 2005    Post subject: Reply with quote
How can that cause it? Confused They get stuck to the valve so you can't get them off but that's all I had.
Dom_
Points Mean Prizes
PostPosted: 22:23 - 26 Jun 2005    Post subject: Reply with quote
The force of a 1g weight spinning at 120mph could rip the valve out. Wink
ash t
PostPosted: 22:25 - 26 Jun 2005    Post subject: Reply with quote
Centrifugal Forces on the valve, fair bit of force when you think about it. Heavy Dustcap.....
I threw away the dustcaps and pumped it up...it was Ok on the way back
Going to get it checked out anyway!
Jrod
Page 3 Girl
PostPosted: 22:40 - 26 Jun 2005    Post subject: Reply with quote
They can't weigh much more than the plastic ones. Confused
Gazdaman
I did a trackday!!!
PostPosted: 22:43 - 26 Jun 2005    Post subject: Reply with quote
Centripetal force.
And I suspect if you'd pumped it back up and put the dust cap back on you would have had the same thing.
Maybe a dodgy valve? keep an extra close eye on your tyre pressures for the next few weeks!
Gaz
Dom_
Points Mean Prizes
PostPosted: 22:46 - 26 Jun 2005    Post subject: Reply with quote
We threw the valve cap away...
Ash said "Dom the front end feels funny on roundabouts" i replied, "yes Ash, this is because you have a flat tyre Shocked" lol.
ash t
PostPosted: 22:47 - 26 Jun 2005    Post subject: Reply with quote
LOL i was commenting on the temperature of the front tyre...and as usual, you had to play with it and noticed it was flat Razz Good thing really!
Gazdaman
I did a trackday!!!
All I'm saying is how do you know the dust cap was at fault? It would have to be pushing in on the centre bit of the valve to deflate it.
I'd suspect a dodgy valve or even a puncture is more likely.
Gaz
ash t
PostPosted: 22:49 - 26 Jun 2005    Post subject: Reply with quote
We pumped the tyre back up and its fine now after a 40 odd mile trip back, 2 up doing natonal speed limit
cagiva gezzer
PostPosted: 22:54 - 26 Jun 2005    Post subject: Reply with quote
I fail to see your logic. I can see how tyre flys can cause issues, but not alu versions of normal caps.
divuk83
PostPosted: 22:57 - 26 Jun 2005    Post subject: Reply with quote
I don't see how there is any difference in weight between ALU dustcaps and plastic ones. Stupid ones with LED's and other novelty things on them would be heavier. Only thing with alu ones is they need cooper greasing or they will never want to come off.
Dave
ash t
PostPosted: 23:02 - 26 Jun 2005    Post subject: Reply with quote
They are heavier.
Just had afriend tell me his mates tyre did the same and it turned out that it was the valve core which needed replacing.
I will have to take it to the local tyre place in the morning.
cant be having a dodgy tyre!
Mr C
PostPosted: 23:23 - 26 Jun 2005    Post subject: Reply with quote
we have had problems with the plastic dustcaps causing rapid deflations at VERY high speeds
at over 180mph the centripetal force on the inside of the valve is enough to open it wide - just liek sticking an object in
the pressure in the tyre is then enough to either pop the cap off or split it in two
now when top speed racing most of us will only use the little steel ones with the rubber o ring inside as they stay on, don't split and don't let the air out
fucking about with "novelty" dustcaps is inexcusable Rolling Eyes
187.3bhp = 201mph
ash t
PostPosted: 23:32 - 26 Jun 2005    Post subject: Reply with quote
What else could it be?
Jrod
Page 3 Girl
PostPosted: 23:37 - 26 Jun 2005    Post subject: Reply with quote
Riding too slowly? Wink
ash t
PostPosted: 23:54 - 26 Jun 2005    Post subject: Reply with quote
Definately not Exclamation
TOM M
PostPosted: 00:25 - 27 Jun 2005    Post subject: Reply with quote
its a good thing that you didnt bin it............thats one very sexy cbr to bin Very Happy
Now owner of a 1200 Bandit
loply
PostPosted: 00:49 - 27 Jun 2005    Post subject: Reply with quote
My tire had an anodised cap on it (previous owner) and I had to have the valve ripped out and revalved at a tire shop, because it completely seized itself to the valve.
All the BAD stories Ive heard about anodised caps- And you still get idiots buying them!
Yamaha SZR660 Caution to the wind, the throttle pinned!
ash t
PostPosted: 13:34 - 27 Jun 2005    Post subject: Reply with quote
Checked they tyre pressures thismorning and they are all hunky dory.
Im rather confused!
I would go and get it checked but i dont have money to pay anyone to fix it Question Confused Shocked
My dad just says keep and eye on it over the next few days
Major_Grooves
The Doctor
PostPosted: 14:05 - 27 Jun 2005    Post subject: Reply with quote
I didn't hear the stories, I just saw the shiny gold.... Sad
Haven't put any air in my tires for ages. Confused
About me|@Major_Grooves|My company|Digg|Flickr
mchaggis
PostPosted: 14:37 - 27 Jun 2005    Post subject: Reply with quote
On a slight tangent I nearly got clobbered by a flying plastic wheel trim from some orange Fiat thing the other day. Confused I noticed the car had lost two on one side, you'd have thought they might have checked to see if they were secure? Neutral Thumbs Down
Anodised dust caps will sieze onto the threads of a valve, requiring the whole valve to be removed in order to get them out.
I would like to clarify that the dustcap cannot be pulled off by the mythical centrifugal force. It is pushed into the valve by the reaction to the centripetal force. All dust caps will suffer from it to some degree, plastic or metal, just metal ones, being heavier, will exert a greater force on the valve for the same wheel speed. Hence why you can get special ones for high speeds as Mr C described.
One of the main benefits to plastic ones in my eyes anyway, is that plastic ones can be pulled off without damaging the thread on the valve itself. They're also cheap as chips.
I must not be a troll...
Mmmm, Guinness
Mr C
PostPosted: 14:45 - 27 Jun 2005    Post subject: Reply with quote
you miss the point mate
at high speed, the valve opens due to centripetal force acting on the little pushy down bit in the middle being greater that the spring and tyre pressure keeping it closed
plastic caps don't contain the pressure once this has happened
steel ones do
187.3bhp = 201mph
mchaggis
PostPosted: 14:47 - 27 Jun 2005    Post subject: Reply with quote
Doh!
Ah, of course! Embarassed I can't believe I didn't think of that.
That makes better sense. Thumbs Up
What do they make the cores from? Ordinary steel? There'd be some mileage in composite valve cores I reckon, though the pressure proof caps would still be cheaper and easier. Thumbs Up
Mmmm, Guinness
PostPosted: 14:52 - 27 Jun 2005    Post subject: Reply with quote
If you try to enter the Manx Grand Prix with plastic dust caps on, your bike will fail scruitineering. They claim this is because under the sustained high speed round the circuit, the centre of a plastic cap can deform and press down on the valve.
I would suggest the problem is either a slow puncture, dodgy valve core or the tyre isn't quite seated propely on the bead and is leaking a little (which in my experience reaches a certain point then goes completely flat all of a sudden).
Throw away the anodised alloy valve caps anyway or I will send the fashion police round. They are like, soooo late 80's man. Wink
Get some of those nice metal ones with the built-in valve core extractor on top. Functionality of design Thumbs Up
The last post was made 21 years, 54 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.21 - MySQL Queries: 15 - Page Size: 131.75 Kb
