| Mockey |
 Mockey Scooby Slapper
| stinkwheel |
| Mockey |
| Mockey |
 Posted: 20:25 - 28 Jun 2005 Post subject: |
I've figured out that that from www.performancemotorcycleparts.co.uk I can get LASER downpipes for £99 and JAMA mufflers for about £229. Much better price than £540! Me and my mate could fit them no probs...
If I order the Pipes and the Mufflers will I need anything else in order to fit them? Will I need to weld them together (there called slip on mufflers)
Jack ____________________ 04/05- Kawsaki Eliminator 125, 05/06 - Kawasaki EN500, 06/present - Triumph Thunderbird 900 |
| stinkwheel |
 Posted: 20:38 - 28 Jun 2005 Post subject: |
You should just need two new exhaust manifold gaskets for under the top of the header pipes (about a quid each) and possibly some assembly paste for where the two parts join (although many will seal well enough without). ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Mockey |
| dodsi |
 dodsi Dirty Carny
| Mockey |
| stinkwheel |
 Posted: 21:01 - 28 Jun 2005 Post subject: |
Looks like the parts should join in an airtight maner. You will still need two exhaust gaskets (they go between the engine and the header pipe, either copper or fibre), I don't see any on the diagram. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Mockey |
| stinkwheel |
 Posted: 21:24 - 28 Jun 2005 Post subject: |
No, the exhaust gaskets are a use-once then throw away part. They cost a whole British pound each! If you reuse them your system will not seal as tightening them down crushes the gasket into shape.
A traditional one is a ring of hollow copper tube, the tube squashes flat as you tighten down the bolts and seals any little gaps between the engine and the exhaust. If you get leaks here, the bike will pop and bang like a rally car. The engine will also run slightly lean which is not good for it. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Mockey |
 Posted: 21:30 - 28 Jun 2005 Post subject: |
Are these standard or are they made differently for different models and how do you fit them?
Sorry for all the questions, just I'm not that mechanically minded... don't worry though my mate is a mechanic  ____________________ 04/05- Kawsaki Eliminator 125, 05/06 - Kawasaki EN500, 06/present - Triumph Thunderbird 900 |
| stinkwheel |
 Posted: 22:10 - 28 Jun 2005 Post subject: |
It is a loose washer that fits inbetween the engine itself and the exhaust. You need to get one that is the correct diameter so it fits in the hole. Your kawasaki dealer should keep you right if you ask for two exhaust gaskets for an EN500.
Below is a picture taken looking at an engine from where the exhaust usually attaches. You should be able to see the old, squashed, copper gasket in place. You would need to remove this and put a new one in there before clamping down the exhaust on top of it.
They settle a bit too so you would want to re-tighten the nuts after 100 miles or so.
https://faq.f650.com/FAQs/Photos/HGasketValvePhotos/ExhaustSeals3.jpg ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| instigator |
 instigator Super Spammer
 Posted: 22:30 - 28 Jun 2005 Post subject: |
On a bike that age, just be careful on taking the exhaust bolts off. If they won't budge initially, don't apply more and more force, like myself.
Was just going to recommend laser as well. |
| stinkwheel |
The last post was made 21 years, 91 days ago. Instead of replying here, would creating a new thread be more useful? |
