Mounting Bike Cam and Digital Recorder
KevTM
PostPosted: 23:06 - 28 Jun 2005    Post subject: Mounting Bike Cam and Digital Recorder Reply with quote
So i got one of those hi-res Sony bullet cams and an Archos AV420 Digital Video Recorder.
I quickly set it up, camera powered off battery on bike, cam velcro'd to front of bike, wires routed under seat and put the DVR under the seat also.. anyway..
I can't get a recording when i leave the DVR under the seat i think due to vibrations, once i got a corrupted file, most other times it just turns off for some reason Confused I've tried putting the DVR in my pocket and it's worked twice (out of 4 times), twice it switched off again. I don't know whether it's vibrations or buttons being pressed..
So i'm wondering what's the best method of storing DVR's under the seat to keep vibes to the minimum? between a couple of sponges, foam, gel? The camera i can mount no probs really but i want to find a discrete place for it in case i get stopped by the law!
Anyone got any experience with these specific/similar items or any ideas on how to get vibrations to the minimum?
cheers.
(got 2 alright vids today, not speeding but a couple of bikes passed by at a good old trot!) Smile
Bendy
Mrs Sensible
PostPosted: 23:33 - 28 Jun 2005    Post subject: Reply with quote
I'd be tempted to put it in a rucksack, use yourself as the shock absorber.
I've read a few things where people have tried a HD based recorder with very little luck due to the vibes, one of the reasons I'm sticking to tape for now.
DisabledRider
PostPosted: 23:38 - 28 Jun 2005    Post subject: Reply with quote
If u wanna go down the hdd route, seagate now make a hdd tat can stand alsorts of vibrations...
KevTM
PostPosted: 23:45 - 28 Jun 2005    Post subject: Reply with quote
thanks for the replies.
i really wanted to keep the whole system within the bike to save 'plugging' myself in every mount/dismount. I'll try the rucksack idea anyway to identify whether it is pure vibrations that's causing the unit to go off or not.
I'm not sure if i can change the HD but it does have a Hitachi drive in it and they seem pretty proud of the fact as there's a big red Hitachi sticker on the back of the unit.
any more ideas from the clever clogs?
Silver
PostPosted: 23:48 - 28 Jun 2005    Post subject: Reply with quote
I've got the RF Concepts hi-res "Sony" bullet cam (the one I assume you're talking about) and I have it linked up to a Sony MiniDV camcorder under the seat. Only once has it turned itself off (and that was probably my fault for just chucking it all under the seat in a hurry!). Normally it's absolutely fine, I just wrap it in an old towl to stop it banging around and damaging something.
KevTM
PostPosted: 23:49 - 28 Jun 2005    Post subject: Reply with quote
thanks Silver,
do you mean the camera powers itself off or the MiniDV recorder? The camera itself is always fine so i'm happy with that but i didn't think the DVR would go off due to too much vibrations..
i've emailed ARCHOS about the "powering off" issue and a few other questions i wanted answers to..
Silver
PostPosted: 00:09 - 29 Jun 2005    Post subject: Reply with quote
It was the camera, but I don't think that's a fair comparison as it was probably my fault for hurrying. I did have the batteries fall out of the power supply for the camera once, so now I tape them in with duct tape, problem solved.
I've done three track days with the camera now and got well over three hours of footage with little problem. It's a great camera, so I'm suspecting your DV recorder. I don't know anything about the Archos ones though I'm afraid - I doubt vibrations would cause the bullet cam any problems.
KevTM
PostPosted: 00:14 - 29 Jun 2005    Post subject: Reply with quote
the bullet cam is aok. i power mine from the battery on the bike so i don't have ny connection issues or another bulky set of batteries under the seat and it's totally fine, you may want to try that. Definitely going to use a voltage regulator on it though if i can get one that's 12v in - 12v out (or some other method anyway)
It's the DVR that's cutting out/powering off but i don't quite know why yet. Need to dampen the vibrations anyway as i don't want to ruin my HDD and i suspect that's the primary problem anyway.. it can only be that!
ingenious ideas are required lads, tell me your vibration dampening ideas Thumbs Up
instigator
PostPosted: 00:18 - 29 Jun 2005    Post subject: Reply with quote
Let me know when she's up and running and we can go and test it on a decent road...Wink
Tank bag maybe? I put my old DV camcorder in one of them and didn't suffer whatsoever...mind you, it's easily nickable up there if you happen to dismount and bugger off. Sad
Bendy
Mrs Sensible
PostPosted: 00:22 - 29 Jun 2005    Post subject: Reply with quote
Foam, foam and more foam.
KevTM
PostPosted: 00:25 - 29 Jun 2005    Post subject: Reply with quote
well i've got an Oxford seat bag thing that straps around the pillion seat so at worst i suppose i can use that and wrap the DVR in various dampening materials, towels, foam, bubble wrap etc.. saying that though i'd still rather have it under the seat for convenience.
Will definitely give you a shout when it's installed properly Thumbs Up some decent weather coming in now, too.. today was absolutely roasting! Shocked
lol i like your thinking. Good thing is it's just a little plastic tray under the seat that's been held in with a few tie-wraps so i could even replace that for something a little more vibe friendly, and possibly even bigger..
I'll try some foam etc tomorrow and let yous know how i get on.
Cheers for the ideas Very Happy
WishayKillie
PostPosted: 01:36 - 29 Jun 2005    Post subject: Reply with quote
Does anybody have a link as to where you can get these bullet cams.
I've got a Sony DCR-HC40 (Mini DV) camcorder, would a bulled cam just plug in??
KevTM
PostPosted: 01:40 - 29 Jun 2005    Post subject: Reply with quote
https://www.rfconcepts.co.uk/helmet_cameras.htm
^ bullet cams! Cool
don't know if it'll plug into your MiniDV, Silver's prob your man for that.
Silver
PostPosted: 01:44 - 29 Jun 2005    Post subject: Reply with quote
As long as you have an AV input, it's fine. Buy the kit from RF Concepts and it comes with all the cables, mounts, mics etc that you need (I got "Complete Pack 3").
WishayKillie
PostPosted: 01:48 - 29 Jun 2005    Post subject: Reply with quote
I'll check when I get home. I've got a funy feeling it's only outputs that are on mine i.e. Firewire and USB Sad dont think it's got a AV point (bollocks Evil or Very Mad )
F**K it I'll just Ducktape it to the tank Twisted Evil
Cheers for the replies (bloody quick for 1AM Thumbs Up )
KevTM
PostPosted: 01:50 - 29 Jun 2005    Post subject: Reply with quote
same one as i got! Wink
CBRnick
PostPosted: 09:50 - 29 Jun 2005    Post subject: Reply with quote
If you have a digital camcorder, you will be wanting a DV in connection, not an AV in.
Kind of defeats the object of a digital camcorder if you feed it an analogue stream.
Bendy
Mrs Sensible
PostPosted: 11:45 - 29 Jun 2005    Post subject: Reply with quote
No, he'll be wanting AV in as the bullet cam is analogue.
It defeating the object is presumably one of the reasons that very few DV cams have an AV in socket.
KevTM
PostPosted: 12:06 - 29 Jun 2005    Post subject: Reply with quote
yeah the bullet cam is your usual composite video signal.. i.e. analogue.
I've managed to make up a little mount for the camera to screw onto between the headlight and the horn. It's as discrete as i can get it (bloody difficult with a naked bike). Routed the wire to the front, too, so all the camera work is done.
I would start messing about with the underseat part, i.e. larger tray, foam, buble wrap etc but as usual it's pissing down Evil or Very Mad (usual carry on after a glorious day yesterday Confused).
Updated the firmware on the DVR as well to get rid of any bugs. Apparently the older firmware (the one i had) used to turn off occassionally when recording audio so hopefully that's related and it's been sorted now.
Anyway, going to keep my eye on the rain, argh!!
KevTM
PostPosted: 20:15 - 29 Jun 2005    Post subject: Reply with quote
right well i tried various stuff today, foam under the seat, still crap; luggage bag, towels, foam, bubble wrap, more foam and bubble wrap, still crap; tried mounting it vertically, no difference, upside down, no difference.. so after a bit of a depressing time of it all i put it in my top pocket and viola, works all the time Cool
Only problem is my bodged connector needs redone (done it in a hurry last time) so i'll do that properly. My microphone i got in the camera kit is too loud, major distortion, so i'll need to stick a variable resistor inline with it.. 1k? 10k?
then i'll get a 5v regulator and power the DVR from the bike as well as i'm not confident the battery will last a long time recording.
*phew*.. so, top pocket it is!
Silver
PostPosted: 12:38 - 10 Jul 2005    Post subject: Reply with quote
Where did you get the cable to do that? Does it connect in the same way as the battery pack? RF Concepts don't seem to do their own.
The last post was made 21 years, 43 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 113.3 Kb
