Clutches
Kram
PostPosted: 12:43 - 05 Jul 2005    Post subject: Clutches Reply with quote
looks like i'm in need of a new clutch Sad . how much will one set me back (how much do you guys pay for them) and also, how easy are they to fit. or shall i get it done, proffesionally?
what would need replacing? plates, or plates and springs, etc.?
btw. the clutch slips when over 7k, pulling hard in 3rd and up
thanks guys.
Drummer
FS1E -> SR125 -> CB400N -> CB650 -> FZR600 Genises -> VFR400 NC21 -> CBR900RR Fireblade -> Renault Clio 1.4
PostPosted: 12:48 - 05 Jul 2005    Post subject: Reply with quote
Not that much, but depends on what plates you get, etc. New Barnett plates and springs for the FZR were about £125, EBC plates under half that.
On the FZR it is an easy job. About 10 bolts holding the clutch cover on. Then 5 bolts holding the pressure plate on, then you can just take the plates out, put in the new ones and bolt it back together. None of the bolts are done up with any great torque.
Black Knight
PostPosted: 12:51 - 05 Jul 2005    Post subject: Reply with quote
im having mine done at a garage at the moment.
FZR600 Genesis.
IIRC he said around £65 for plates, springs and gasket.
Labour would be an hour.
Where does a turn end? 'Where you can do anything with the gas you want to, where you are brave again, where your attention is free from the turn, where you are sure you can do it better next time; that's the end' - Keith Code.
Kram
PostPosted: 09:06 - 06 Jul 2005    Post subject: Reply with quote
i tried adjusting the clutch (under the rubber cover, not at the lever) and when i tried to undo the locknut, the entire bolt turned? is there an easier way to adjust it?
btw. the bite point is about 10mm from the lever being all the way out
PostPosted: 11:03 - 06 Jul 2005    Post subject: Reply with quote
Sounds like the adjuster is not working correctly, or the lock nut was not done up. Free off the screw from the lock nut and give it a try. Biggest problem will be finding a suitable size socket to tighten the nut which still gives you access down the centre to hold the screw.
The last post was made 21 years, 134 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.21 - MySQL Queries: 13 - Page Size: 45.61 Kb
