Using a rear paddock stand on your own?
Dracan
PostPosted: 19:36 - 07 Jul 2005    Post subject: Using a rear paddock stand on your own? Reply with quote
I've got a rear paddock stand, but I can't put the bike on it without someone holding the bike up straight first. My GF managed to do it once, but nearly dropped it, and is scared to try again. Is there any techniques anyone knows for one person to put a bike on a stand?
Cheers,
Dan.
Honda CBR600RR - 2004
Sparky
PostPosted: 19:40 - 07 Jul 2005    Post subject: Reply with quote
Hmmmm no not really, i leave the side stand down slide the stand at an angle under the back and hold the back of my bike with one hand and slowly lift the back end up. done it loadsa times but i know exactly what you mean its a tricky bugger i still get butterflies about it dropping now when i do it!! Embarassed
Previous zxr400 - Current ZXR636 late'03
*Who ever said nothing is impossible never tried slamming a revolving door!*
kb-zxr
PostPosted: 19:41 - 07 Jul 2005    Post subject: Reply with quote
One of my mates could on his Hornet. My micron stand instructions say must be operated by two people, and im too scared to try on my own.
I wouldn't risk it mate.
Kurt
PostPosted: 19:47 - 07 Jul 2005    Post subject: Re: Using a rear paddock stand on your own? Reply with quote
I just hold the back of the bike while placing the stand underneath, then push up Smile
As sparky said, if you've got a side stand, you can leave the bike on the side stand. Then place the left hand bit off the padock stand under the left hand swing arm. Push down on the stand while steadying the bike at the back.
If you've got the right hand side lined up it should slot in fairly smoothly.
zaknafien
PostPosted: 19:59 - 07 Jul 2005    Post subject: Reply with quote
I just put the stand under then push down and lean the bike up as i'm doing it, not had a problem so far and never had help.
02 Firestorm.
Chriss
PostPosted: 20:00 - 07 Jul 2005    Post subject: Re: Using a rear paddock stand on your own? Reply with quote
Call me pedantic, but don't you push down? Wink
I've used a paddock stand hundreds of times by myself, only once had a problem when lowing the bike, I forgot I put the side stand up, and nearly dropped it, I didn't though.
Now I just use a check list. Smile
TheShaggyDA: I've got 3 or 4 pairs that predate my wife, so at least 11.5 years old.
mistergixer
PostPosted: 20:04 - 07 Jul 2005    Post subject: Reply with quote
I put a piece of wood under the sidestand to get it a bit more vertical, then use the paddock stand.
Bobbins help, a lot more positive than those shitty rubber cups.
Space Monkey #7
the grim reaper
PostPosted: 20:21 - 07 Jul 2005    Post subject: Reply with quote
I've always done mine on my own and never had a problem. I just line both sides up and take it easy. I also make sure to keep the pressure on the handle when lowering it back down.
Grim
mistergixer
PostPosted: 20:34 - 07 Jul 2005    Post subject: Reply with quote
To get the bike off the stand, i sit on the bike, brace my feet against the wheels of the stand and rock it forward gently.
Space Monkey #7
Lee_367
PostPosted: 21:45 - 07 Jul 2005    Post subject: Reply with quote
I've always used a block of wood under the stand too. Thumbs Up
?It?s mercy, compassion, and forgiveness I lack?not rationality.?
fazed
Korn is my hero!
PostPosted: 21:54 - 07 Jul 2005    Post subject: Reply with quote
Put one side of the paddock stand on first (left) and push down on stand and guide it into place you will of course be standing towards the right of the bike I do this on the TLR on my own and it isn't exactly small or light.
gixxer thou K6 , Cbr400 gullarm x 2 , cb400 superhack.
Dom_
Points Mean Prizes
PostPosted: 22:01 - 07 Jul 2005    Post subject: Reply with quote
My stands a flip up one anyway, so as soon as you tilt the bike over it springs up.
I've got a Micron rear paddock stand and have never had a problem using it on my own. Smile
Just get the stand underneath the swingarm, and lever the bike upwards...
ash t
PostPosted: 22:05 - 07 Jul 2005    Post subject: Reply with quote
I just line the cups/hooks up, and use my foot to push the stand down, while standing at the side of the bike.
To take the bike off the stand, I put my foot by the wheel of the stand, and push the bike forward. Thumbs Up
When You're Starting To Choke, Take Some Pills With Your Coke, Its Hyserical
Kirmit
PostPosted: 10:22 - 08 Jul 2005    Post subject: Reply with quote
I used a car jack on my 125. It was pretty good. Laughing
When riding fast, think fast. When riding slow.. speed up.
Grey Honda Cityfly 125 || Red Suzuki Bandit 600 & Blue Suzuki SV650SK5|| Red Honda VTR 1000-F2
craigs23
Mr Muscle
PostPosted: 10:28 - 08 Jul 2005    Post subject: Reply with quote
Practice? That's how I built up my paddock-stand-prop-ups.
Get a friend (or family member) to support the bike whilst I jack it up on the paddock stand. Then ask them to loosen their grip more and more, whilst you find a position where you can both support the bike and jack it up (use them as a 'just in case'). You'll soon adopt your own knack of doing it single handed, but have the comfort knowing that someone's there to support the bike if anything happens.
scottiel
PostPosted: 12:58 - 08 Jul 2005    Post subject: Reply with quote
Hold back of bike place stand underneath push down, job done easy peasy.
phill.c
PostPosted: 13:02 - 08 Jul 2005    Post subject: Reply with quote
i just stand on the other side of the bike to the side stand (so if it falls). balance it with my body, put it in place then push on it with my foot.
job a good-on
CBR400RR the funs started - Honda MTX 125 ongoing project when i can be arsed Smile
cbrbiker
PostPosted: 13:05 - 08 Jul 2005    Post subject: Reply with quote
Just what I was gonna say. I use a couple of thin planks of wood which brings the bike almost upright, then use the stand.
Tell you what though, it's a laugh doing the front one on your own!
My Bikepics page
www.trackdaypix.com
spitfire
PostPosted: 13:06 - 08 Jul 2005    Post subject: Reply with quote
I have 2 rope loops hanging from the beam in the garage I hook them around the bars, that keeps the front end steady, just to be on the safe side I still loop my arm around the rear of the bike and grab the pillion foot peg mount, then push the stand down with the other arm.
works a treat !
fuzz
PostPosted: 13:29 - 08 Jul 2005    Post subject: Reply with quote
Block of wood under the side stand, works just fine.
The last post was made 21 years, 117 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 106.72 Kb
