Oil dropping
shammon
PostPosted: 23:55 - 08 Jul 2005    Post subject: Oil dropping Reply with quote
Oil level seems to be dropping and needing toped up more than what is normal? (Honda sh50) any idea what is the most likley cause?
White Noise
Mr Dudwee
PostPosted: 00:43 - 09 Jul 2005    Post subject: Reply with quote
is there any ovious leaks? does the bike give out a lot of blue smoke?
WN
Davo
Davo To The Rescue!
PostPosted: 01:42 - 09 Jul 2005    Post subject: Reply with quote
WN
Mike it's a 2 stroke, there will be a little bit of blue smoke.
shammon
PostPosted: 03:53 - 09 Jul 2005    Post subject: Reply with quote
Only a bit of blue smoke at start up? No leaks either.
White Noise
Mr Dudwee
PostPosted: 06:50 - 09 Jul 2005    Post subject: Reply with quote
if there is only a little at start then its probibly not burning gearbox oil.
how often do you usually top her up? and have you been riding in a different manner?
WN
Guest
PostPosted: 10:59 - 09 Jul 2005    Post subject: Reply with quote
Assuming it's a stroker, are you talking about the seperate two-stroke oil tank or some sort of gearbox/rear drive oil level? I've no idea what an SH50 is Confused
If it's the two stroke tank then it needs topping up regularly, if it's the gearbox/rear drive then it needs sorting.
shammon
PostPosted: 11:52 - 09 Jul 2005    Post subject: Reply with quote
Its a Scooter 2 stroke and its the main oil feed to the engine Happily not the gearbox Smile Dont have to top it up daily but more like weekly and then only a small amount. The engine is pushed hard cos im a fat Bstard lol. Was not sure if this was normal for scooters.
bish777
PostPosted: 12:33 - 09 Jul 2005    Post subject: Reply with quote
2 strokes run total loss lubircation-the oil is squirted into the crankcase by a pump. This is becasue the piston itself helps to pump fuel into the cylinder, the crank case cant contain alot of oil so it need to be squirted in in small amouunts-hence the level dropping on the oil tank on your ped.
GSXR1100J
Guest
PostPosted: 12:47 - 09 Jul 2005    Post subject: Reply with quote
Ah gotchya. As bish says, it's designed to use the two stroke oil. Check the level regularly and keep it topped up - if it runs out then serious engine damage will ensue, and it could have you off if the engine locks up.
shammon
PostPosted: 23:27 - 09 Jul 2005    Post subject: Reply with quote
Thumbs Up cheers.
The last post was made 21 years, 108 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.22 - MySQL Queries: 13 - Page Size: 61.98 Kb
