Maplins..bike alarm?
JodieWodie
Reflective Banana
PostPosted: 10:06 - 09 Jul 2005    Post subject: Maplins..bike alarm? Reply with quote
Someone I know from work, (but cannot get hold of), said he got some kind of alarm from Maplins electrics shop for his Thundercat.
He said it was only £15 and it works on the basis of a level, and if the bike moves, alarm sounds.
Now, I have looked and cannot find it.
I basically need some kind of cheapish alarm for the FZR.
It will be out front, so it needs securing.
We are concreting a ground anchor in today, buying another chain, a disc lock too.
Any help greatly appreciated,
J xx
Courage doesn't always roar. Sometimes courage is the quiet voice at the end of the day saying, "I will try again tomorrow"
rK@NE
PostPosted: 10:26 - 09 Jul 2005    Post subject: Reply with quote
I've had a look and I can't see any prebuilt alarm systems although there is a motorbike alarm module (Order code: N80AW) which connects between the battery and the horn. When there is movement the connection is made in the module and the horn goes off. You'll also have to buy a switch to put in line with the module so you can turn it off if it's been activated.
It's not ideal but the module is only £3.99 and a switch would cost less than a quid, just takes a little effort to set it up thats all.
PostPosted: 10:37 - 09 Jul 2005    Post subject: Reply with quote
You can get a cheap alarm on ebay for about £25.
These are 'proper' bike alarms, with imobaliser and usually fancy bits like remote start as well.
Dave-O
PostPosted: 22:18 - 09 Jul 2005    Post subject: Reply with quote
What I dont understand is why people spend thousands on a bike, then 20 quid on a cheapo alarm.
As soon as I got my bike, I had a Datatool 3 fitted. If your bike cost 30 quid then o.k get a cheap system.
"I know not with what weapons World War III will be fought, but World
War IV will be fought with sticks and stones."
-- Albert Einstein
lurker
PostPosted: 23:38 - 09 Jul 2005    Post subject: Reply with quote
something i didnt realise b4 with alarms is that most of them including datatool which i found out to my expense only have a 3 to 4 year life on the bike.
you just have to hope that they dont go when youre miles from home
cause its a bugger to take them out and redo the wiring on the bike.
didnt believe this and thought i'd just got a dodgy one but various bike shops have since told me the same thing.
tatters
Exxon Valdez
PostPosted: 23:40 - 09 Jul 2005    Post subject: Reply with quote
the 8 year old datatool system on my ZZR250 worked fine, as long as the fob batterys are ok they should last as long as any other electrical part of the bike.
JodieWodie
Reflective Banana
PostPosted: 11:09 - 10 Jul 2005    Post subject: Reply with quote
Thanks for all that..
The dealer said that alarms drain the battery dreadfully.
In fact, while we were there, he went to four bikes that had alarms on and all their batteries were knackered.
True ?
PostPosted: 14:33 - 10 Jul 2005    Post subject: Reply with quote
The alarm doesn't seem to drastically reduce insurance premiums.
So the next bit is - if someone tries to steal it, are they going to attempt to get the alarm out?
If so, I would suggest it's quite probable that they know how to get any alarm out, be it a very expensive one or a cheap one.
Yes, the expensive ones are harder circumvent - but if someone's going to try anyway, they probably know how to do either pretty quickly.
I would suggest the money is better spent on a decent lock along with a cheap alarm.
Ok, if you're talking about a £7k bike, then I could feel some justification for wanting to spend lots on an alarm, but if you're talking around a £1k-2k bike, you're talking 15%-30% of the bike's value which you won't massively re-coup when you sell the bike, spent on an alarm.
For a dealer alarms might drain the battery - but if your bike has a healthy battery and is run fairly regularly (says once a week, though most alarms seem to be fine for a month or so, from what I've seen) you shouldn't have a problem.
scottiel
PostPosted: 16:18 - 10 Jul 2005    Post subject: Reply with quote
I put an ACUMEN on my FZR, bought it for £70.00 brand new and bought a tricklie charger to match for £30.00. I put the trickle charger on the bike once a week over night and it does the trick.
mr.z
PostPosted: 16:33 - 10 Jul 2005    Post subject: Reply with quote
Unfortuneately nobody takes the tinyest bit of notice when an alarm goes off, house alarms, car alarms, all just get ignored...
Only way i'd bother is with a pager attached, so you can go and give the tea leafts a good kicking youself...
Actually considering geting a baby monitor and putting that on the bike...
Imobilisers will only stop opertunist pikeys, even then allot will get arround it..
The according to a guy i spoke to working at a dealership, vast majority of bikes going into there that wont run 70% of them are down to dead batterys from alarms or mainly imobilisers Rolling Eyes
PostPosted: 17:23 - 10 Jul 2005    Post subject: Reply with quote
I've got an alarm so that I will take notice (and for the tarty remote start Smile ).
Hopefully it would at least give a causual thief some second thoughts, so they move on to another bike.
zaknafien
PostPosted: 17:39 - 10 Jul 2005    Post subject: Reply with quote
Noone except yourself care's about the alarm going off and it's not worth the £10 reduction on the insurance premium.
02 Firestorm.
easy
PostPosted: 18:23 - 10 Jul 2005    Post subject: Reply with quote
OK one night during the winter, I walked up to the company car-park and found that some pikey had put my window through, smashed the steering lock and ignition and tried to have it away with my 14-year-old astra.
The car has a 2.0l engine, so I had a cat 1 fitted and a mul-T-loc (like a large U bolt thet goes round the gear-lever).
Undo the Mul-T-loc, check the steering is OK and then I jammed a screwdriver into the ignition and drove home.
If I hadn't have had the alarm I'd have had to either get the bus/taxi or wait for the Mrs to pick me up.
In my opinion alarm/immobilisers are worth having if for no other reason than they help stop have-a-go pikeys from getting lucky and reduce the risk of you being seriously put out by having no bike (or in this case, car), not to mention a lot of arse-ache with the insurance (if/when the find the sooty, blackened mess that was once your pride and joy).
Each to their own though.
The last post was made 21 years, 42 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.44 - MySQL Queries: 15 - Page Size: 79.09 Kb
