| Retro-Man |
 Retro-Man Traffic Copper
 Posted: 21:05 - 19 Jul 2005 Post subject: U turns |
Just wondering, How many people struggle with U turns and more to the point is it specific bikes you struggle with .
This comes about because I have found that I can not, no matter how hard I try get an ER5 through a U turn, I can however turn a CG125 fairly easily and My VFR400 is a piece of piss to take through a U turn.
Which by all accounts is a fairly unusual position to be in  ____________________ https://domharnessphotography.webs.com |
| Flip |
 Flip Super Spammer
| instigator |
 instigator Super Spammer
| impaler |
 impaler Crazy Courier
 Posted: 21:28 - 19 Jul 2005 Post subject: |
Everybody struggles with them on their test. Slow riding is the hardest part of riding a bike and it is in the test to show you can do it (rather than as the way you are expected to do a turn in the road).
It is surprising how much you start to use the 'slow riding' technique after you have passed your test, especially in heavy town traffic.
It is definatley easier on some bikes than others. Utter piece of piss on my supermoto. Tricky on a Harley. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| G |
 G The Voice of Reason
 Posted: 21:28 - 19 Jul 2005 Post subject: Re: U turns |
I can't think of many situations where I've had to do a U turn in real life on a bike- and there's always donuts if you need to turn really tightly .
If you practice, it should be easy enough on any bike.
The trick is to overcome your natural instict to shut the throttle as it starts to fall and instead pull it on, then you should be able to do it on the lock on most bikes.
(Though tried this on the KLR while bored and promptly fell over as the turning circle is damn tight!) |
| Retro-Man |
the problem seems to relate to lean, I keep the chain tensioned (constantly driven) controlling speed with back brake and clutch.
I get 3/4 of the way round on the ER5 and then the bike just drops. I have never actually dropped the bike always choosing to put my foot out first.
What I can't comprehend is that on the sports bike I can turn on a sixpence without any loss of balance or instability at all.
I've even tried a ZZR600 which again went round very easily.
My gut feeling is that it is a geometry mismatch between the bike and my rather portly 5ft11 frame  ____________________ https://domharnessphotography.webs.com |
| Zoffo |
 Zoffo Brolly Dolly
 Posted: 21:40 - 19 Jul 2005 Post subject: |
The secret is the use of the rear brake. Use gentle but consistent throttle and use the rear brake to control speed. The idea is that it doesn't affect the arc of the turn as it would if you used the front brake or the throttle to alter speed. ____________________ https://hyperbikes.forumsplace.com/ |
| Retro-Man |
| G |
| craigs23 |
 craigs23 Mr Muscle
| gowenwilliams |
 gowenwilliams Derestricted Danger
 Posted: 22:11 - 19 Jul 2005 Post subject: |
I'd guess if there is a difference, it will be in the rake angle of the forks on the ER5, which I expect is not as steep as your average sports bike.
this will result in a longer front trail, which leads to greater directional stabillity, in a straight line.
In low speed cornering the ER5 will feel more 'heavy' than a normal sports bike, and this will give the effect of "I get 3/4 of the way round on the ER5 and then the bike just drops". Where as the sports bikes have a shorter trail and are therefore more responsive to steering input.
It could also be due to the 'centre of gravity' height. Try with a full/empty tank, might make a difference?
| instigator |
| Retro-Man |
The last post was made 21 years, 103 days ago. Instead of replying here, would creating a new thread be more useful? |
