| JodieWodie |
 JodieWodie Reflective Banana
| stinkwheel |
 Posted: 20:05 - 21 Jul 2005 Post subject: |
Best way is to get someone else to help. We are talkng about nearly 400lb of bike here. Two man lift is definatley the way forwards
I don't know the technique as being a big lad, I can just hump the ting up. Whatever you do keep your back straight and don't strain yourself, it is not worth getting injured over. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| The#Doctor# |
 The#Doctor# Spanner Monkey
 Posted: 20:59 - 21 Jul 2005 Post subject: |
Lift with your legs and not your back  ____________________ CBR125R - CBR600Fy
'140 mph officer thats impossible the bike is 33 bhp restricted' |
| Jrod |
 Jrod Page 3 Girl
 Posted: 21:07 - 21 Jul 2005 Post subject: |
Have you dropped your bike?  |
| JodieWodie |
 Posted: 21:14 - 21 Jul 2005 Post subject: |
| impaler |
 impaler Crazy Courier
 Posted: 21:15 - 21 Jul 2005 Post subject: |
I've never had to do it myself, so don't quote me, but I'm sure you're meant to turn the handlebars so the one nearest the floor is as close to the front of the bike as possible (if you see what I mean). You then grab that handlebar with two hands and lift/push/walk towards the bike. Oh, and try not to put your back out! ____________________ Monster m600
Web, blog, Bikepics page
An optimist will tell you the glass is half full. The pessimist, half empty. The engineer will tell you the glass is twice the size it needs to be. |
| dibbster |
 dibbster Nearly there...
| JodieWodie |
| Milo |
 Milo World Chat Champion
 Posted: 21:55 - 21 Jul 2005 Post subject: |
I've found that squatting in the middle and lifting it by the tank the best way. Obviously the tank isn't designed for sideways forces but it's worked for me.
The handlebard seemed too tricky at the time.
On ice it's a different...and more disaterous story altogether.
It goes something like this...
slip, thud, , slowly picking it up...thud, , slowly pick it up again, try to get leg over to sit on it, slip, thud (on other side ) even more slowly try...careful... ...
Two broken indicators, two broken mirrors and a bent clutch.  ____________________ Shaft drives rule.  |
| Villers |
 Villers World Chat Champion
 Posted: 21:57 - 21 Jul 2005 Post subject: |
My bikes been over three times. Its a CBR600 and weighs about 26 stone dry. I weigh 11 stone wet through!
My technique is to turn the bars to oppostite lock (opposite to the ground) put two hands together with fingers entwined and lift (as said before) with legs and not back. You can back this up with some swearing and grunting, as I find this always helps.
Last time was lifting up against the gradient of a hill and it took some lifting.
I would also reccoment to anyone, if you have dropped the bike by accident then lift it immediately, that way you still have the rage. same applies if you crash, once you are sure you are ok use the adrenalin to pick it up, other than that its going to be a two man 'nice afternoon for a back injury' event!
And heres to no-one one on here never having to lift there bike again.
 ____________________ RS125 > CBR6 > SV650S > ZX636R > GSX1300RZ Hayabusa > 06 RSVR Mille > SV1000S > Street Triple 765 RS |
| gowenwilliams |
 gowenwilliams Derestricted Danger
 Posted: 21:59 - 21 Jul 2005 Post subject: |
My firestorm fell over last year (sidestand melted into hot tarmac)
It was suprisingly easy to get back up, but the best advice would be to leave it on the floor and go and get help, because if you get it 1/2 way up and fail, you'll end up with even more damage and scratches as it goes back down.
I also worked as a race marshall for many years and found the best way for a solo lift was to turn the bars so that the front wheel point skyward (so its on full lock), crouch down, grab both hands on whichever handlebar is nearest the ground, and lifting with your legs, make one quick lifting movement (Doing it slowly always fails). As it comes up about 1/2 way, lean into it, and shove your weight into it with your leg. Careful not to drop it onto the other side!
Practice makes perfect, Unless its a BMW or Guzzi, in which case call for a crane.
(edit) Hi Villers, you just got your post in before me, so sorry for repeating bits |
| Villers |
 Posted: 22:21 - 21 Jul 2005 Post subject: |
No probs! Plus sounds like youve had more experience than me! ____________________ RS125 > CBR6 > SV650S > ZX636R > GSX1300RZ Hayabusa > 06 RSVR Mille > SV1000S > Street Triple 765 RS |
| Kickstart |
 Kickstart The Oracle
| veeeffarr |
 veeeffarr Super Spammer
 Posted: 23:58 - 21 Jul 2005 Post subject: |
| Villers wrote: | My bikes been over three times. Its a CBR600 and weighs about 26 stone dry. I weigh 11 stone wet through!
Hi,
Probably me drivelling on not knowing what I'm talking about, but I wouldn't advise lifting your bike up straight after an accident, let alone any other extremel physical movement for a while, as you probably won't notice the extremity of your injuries until the adrenaline has worn off.
Cheers,
Toby |
| JonB |
 JonB Afraid of Mileage
 Posted: 00:20 - 22 Jul 2005 Post subject: |
I found that adrenaline was a useful help.  ____________________ Be careful whose advice you buy, but, be patient with those who supply it. Advice is a form of nostalgia, dispensing it is a way of fishing the past from the disposal, wiping it off, painting over the ugly parts and recycling it for more than it?s worth. |
| Nath |
 Nath World Chat Champion
| Jamie_ducati |
 Jamie_ducati Scooby Slapper
| ZaphodBeeble |
 ZaphodBeeble World Chat Champion
| paulthewitt |
 paulthewitt World Chat Champion
| Psychonaut |
 Psychonaut Spanner Monkey
 Posted: 08:42 - 22 Jul 2005 Post subject: |
A little off topic but "the long way round" on DVD is 9.99 in virgin sale at the mo. I got a copy last week  |
| Method |
 Method World Chat Champion
 Posted: 09:00 - 22 Jul 2005 Post subject: |
| map |
 map Mr Calendar
 Posted: 09:01 - 22 Jul 2005 Post subject: |
I did put this post in another thread.
Quick guide to picking up a medium sized bike (this works, tried out of necessity)...
Go to side that bike has fallen on
Turn handlebars so wheel is pointing up (bar away from tank)
Face bike and bend knees and place both hands on bar grip, feet either side of bar
Lift by straighten knees with straight back, lifting bars as you go. Lift with legs, not your back.
Shuffle forward to support bike with knee, continue lift and bike should be upright.
Supporting with leg/knee should stop you flipping it over to the other side
Put on side stand and take a deep breath.
That said, I did try this method with big tourer packed full and it wouldn't budge (maybe me just being weak, 2 people lifting was ok).
There is another similar technique with your back to the bike - to see this method click here
HTH  ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger?  |
| FreshAL |
 FreshAL Sir Crashalot
 Posted: 09:49 - 22 Jul 2005 Post subject: |
I've never had to try it, but there's some useful sounding advice from some Yanks on Picking Up A Big Bike - by yourself!
That whole site is quite interesting. US biased, but some interesting stuff there The MS Group |
| AcIdBuRnZ |
 AcIdBuRnZ World Chat Champion
 Posted: 10:14 - 22 Jul 2005 Post subject: |
Trust me - when the time comes, 200kg+ will feel like nothing when trying to save your precious bike.
I hit gravel at less than 5mph in a car park and the front wheel slid away as I was turning into a space - stuck my right foot down and picked the thing up with one leg!!! It's amazing how strong you become in these situations!
Alternatively, watch the Long Way Round and watch how Ewan and Charlie pick up their bikes  ____________________ Past: Honda NSR125R >> Kawasaki ER-5a2 >> Kawasaki ZZR-600e1 >> Suzuki GSXR-750Y >> Honda VTR 1000 Firestorm
"Chickity China the Chinese Chicken..." |
| Kirmit |
 Kirmit Nitrous Nuisance
The last post was made 21 years, 121 days ago. Instead of replying here, would creating a new thread be more useful? |
