cleaning bike up
quik_d
PostPosted: 12:20 - 22 Jul 2005    Post subject: cleaning bike up Reply with quote
hey guys i was just wondering if anyone could suggest how to clean up the engine on my bike, it has been sitting for years and the laquear has corroded and lots like bird shite on the engine casings. I want it off as it ruins the bike, its worse on the clutch cover and the opposite side cover, not so bad on the barrels. I've tried autosol and fine wire wool which worked a treat on the frame but its not touched the engine.
Thanks guys
Quik
LOOK AT DAT M8 WELL LUSH A PARROT INT IT
Sparky
PostPosted: 12:32 - 22 Jul 2005    Post subject: Reply with quote
wire wool didnt work how bad is it!!!
try a bit of wd40 and keep rubbing then autosol it again with wire wool again! you wont get it totally mint but it will lose the corroded bird shite look!
im surprised though the wire wool didnt work the first time!
Thinking
Previous zxr400 - Current ZXR636 late'03
*Who ever said nothing is impossible never tried slamming a revolving door!*
Zoffo
PostPosted: 12:42 - 22 Jul 2005    Post subject: Reply with quote
Sounds like road salt build up which quickly becomes Calcium Carbonate. It's a bugger to shift. Try a water softener on it first.
https://hyperbikes.forumsplace.com/
ZRX61
Victor Meldrew
PostPosted: 20:56 - 22 Jul 2005    Post subject: Reply with quote
First thing is to strip whats left of the laquer off the engine....
& then attack whats left with wet brillo pads for starters & see how far that gets ya.
BTW, *laquer* is just (the wrong name for) clear coat, paint doesn't *corrode*..
quik_d
PostPosted: 23:37 - 22 Jul 2005    Post subject: Reply with quote
zoffo think you are right actually about the calcium carbonate. I think the bike was just put in the garage and left, wasn't cleaned first etc. There was old dried petrol and everything in the carbs as well where it wasn't flushed through before being stored, but anyway......
how is laquer/laquear supposed to be spelt as i had it as laquer it picked it up in spell check and suggested laquaer which doesn't look right! Rolling Eyes
dave1rs
PostPosted: 23:40 - 22 Jul 2005    Post subject: Reply with quote
lacquer Smile
SoND
PostPosted: 01:01 - 23 Jul 2005    Post subject: Reply with quote
What can you use to strip the lacquer off it?
beast rider
PostPosted: 15:49 - 23 Jul 2005    Post subject: Reply with quote
if you are very carefull not to get it in the frame or bodywork you could probably use brake fluid or paint stripper.
quik_d
PostPosted: 18:21 - 23 Jul 2005    Post subject: Reply with quote
attacked the enginer cover with autosol and wirewool again and it came up a lot better. Still loong way to go though Sad
craigs23
Mr Muscle
PostPosted: 12:49 - 24 Jul 2005    Post subject: Reply with quote
An assortment of wire brushes may help - just scrub at it until all the laquers been removed - try wet'n'dry for really tricky bits. Not sure what the engine looks like on your bike, but I'd be tempted to respray with VHT paint to get a nice all round finish - obviously some intricate masking will be required. Then maybe laquer over the top (if it will resist the heat)
The last post was made 21 years, 97 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 62.3 Kb
