Mirrors
Black Knight
PostPosted: 09:24 - 24 Jul 2005    Post subject: Mirrors Reply with quote
I've had problems with the mirrors on my last two bikes. Not visibility but the fact that when every time you get up to a decent speed the hinge becomes loose allowing the mirror to swing backward out of position.
The more you correct it and move it back into position the looser the joint becomes and it seems impossible to tighten up the bolt sufficently to restore to original strenth.
It is just me or is this a common problem?
Where does a turn end? 'Where you can do anything with the gas you want to, where you are brave again, where your attention is free from the turn, where you are sure you can do it better next time; that's the end' - Keith Code.
White Noise
Mr Dudwee
PostPosted: 09:49 - 24 Jul 2005    Post subject: Reply with quote
this can be a problem due to the vibration in the handlebars casing them to loosen, but can be solved by getting a strong thread lock and tighting them very firmly
WN
Black Knight
PostPosted: 09:58 - 24 Jul 2005    Post subject: Reply with quote
Thanks, can you just clarify what you mean by strong thread lock? Is it just a term of tightness or an actual type of nut/bolt?
White Noise
Mr Dudwee
PostPosted: 10:11 - 24 Jul 2005    Post subject: Reply with quote
its like a glue that sits in the thread to lock it in place
https://www.silmid.com/loctite/threadlockers.htm
hope this helps
WN
Black Knight
PostPosted: 10:24 - 24 Jul 2005    Post subject: Reply with quote
Legend - Thank you. Very Happy
White Noise
Mr Dudwee
PostPosted: 13:51 - 24 Jul 2005    Post subject: Reply with quote
there are different types that have various degrees of strength, i think. best to go for one with a medium strength as if you bin the bike and screw the wing mirror it could be near impossible to get the wing mirror stub out with a 'perminant' thread lock
WN
The last post was made 21 years, 102 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.12 - MySQL Queries: 13 - Page Size: 48.35 Kb
