| Cagiva Mito |
 Cagiva Mito Renault 5 Driver
 Posted: 14:09 - 23 Jul 2005 Post subject: What's wrong with my bike?? |
Hello all,
Ok i need some help guy's. I've got an RS125 and I was riding it along this morning when there was this sort of pop or bang and the engine started dying. I could just about manage to keep it going long enough to pull in somewhere, and as I came to a stop the engine just cut out. The bike behaved, and sounded like it had ran out of petrol, but I had just filled it up 5 minutes earlier! I tried to restart it but all I could hear was the starter motor going. So I checked out the spark plug and that was fine so im guessing it had to be a fuel blockage. Anyways I called my breakdown company out (the AA) and the guy took the spark plug out, put his finger over the opening of the barrel and started the starter motor and said there was no compression! He thinks the piston ring has broke but Im not so sure. Ive only had the bike 9 months from new and it shouldnt of gone that quick. Anyway it's at Taz Motorcycles in Peterbourough where they are gonna try and squeeze it in. Its still under warranty so it shouldnt cost much!!!
If anyone has any ideas what it could be pleaaase let me know.
Cheers  |
| mr.z |
 mr.z World Chat Champion
| Cagiva Mito |
| mr.z |
 Posted: 14:46 - 23 Jul 2005 Post subject: |
Depends really.. its a normal maintainace thing, usually best to do before it goes (as you can tell)
If youve only just brought it then if they dont do it for you then kick up a big fuss, not your fault its not been done, as far as your concerned it should go for more than a few months before needing anything like that doing..
If they ask you have kept the oil at the right level and warmed it up propperly before going anywhere and haven't been raging the liveing sheeit out of it.
Chances are they will do it for you as it shouldn't take too much time/money to do, one advantage of smaller bikes...
Good luck geting it sorted  ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| Cagiva Mito |
 Posted: 14:53 - 23 Jul 2005 Post subject: |
Thanx for the reply's Mr Z they have been most helpfull  |
| mrchips |
 mrchips World Chat Champion
 Posted: 17:18 - 23 Jul 2005 Post subject: |
Either that or the bottom end. ____________________ Northern Irish? www.nibikers.com |
| Cagiva Mito |
| quik_d |
 quik_d Could Be A Chat Bot
 Posted: 19:24 - 25 Jul 2005 Post subject: |
might well have had a partial seizure mate, could have snapped a ring and seized, ummmm i reckon it should be covered under warrenty, i mean to me after 9 months thats not a wear and tear job. be honest do you rag it all the time? if yes then thats ur answer, if no then it shouldn't need top end rebuild before about 20,000 miles ____________________ LOOK AT DAT M8 WELL LUSH A PARROT INT IT |
| Cagiva Mito |
| Kickstart |
 Kickstart The Oracle
 Posted: 19:35 - 25 Jul 2005 Post subject: |
Aprilia can be funny about warrenties for seizures. They will not cover cold seizures as that is owner abuse (same for Cagiva). However a heat seizure they should cover. You need to tell them that the bike was fully up to temperature when it went bang, how many miles you had ridden it, etc.
They do recommend checking the piston rings at some of the services (used to be 6000km, which is when I replace them). Most people seem to replace them at 10000km (not sure how many miles you have done on yours).
New parts it is not cheap. Bit of a nasty one as if you fix it the cheaper way (replate the barrel, or fit a Makita barrel kit) then they might well get nasty about the warrenty on other items.
| Cagiva Mito |
| Kickstart |
| Jrod |
 Jrod Page 3 Girl
| Flip |
 Flip Super Spammer
 Posted: 03:55 - 26 Jul 2005 Post subject: |
I too didn't see that one coming either. |
| Jrod |
 Jrod Page 3 Girl
 Posted: 03:56 - 26 Jul 2005 Post subject: |
Hi,
I'm zxr400er and I have a vfr400.  |
| Zero-G |
 Zero-G Scooby Slapper
| Cagiva Mito |
The last post was made 21 years, 99 days ago. Instead of replying here, would creating a new thread be more useful? |
