Throttle stop restrictor has rounded screws.
Reevo8
PostPosted: 09:21 - 28 Jul 2005    Post subject: Throttle stop restrictor has rounded screws. Reply with quote
Right, the monkeys at Honda have managed to bork 2 crosspoint screws on my CBR. How should I get them off?
They are currently attached to the throttle stop which is on the throttle bodies. They need to go back in afterwards, so they are quite important!
05 ZX10R, (**05 WKR) Very Happy
Klause
PostPosted: 11:41 - 28 Jul 2005    Post subject: Reply with quote
So the screws are out? If so just go to your local hardware/auto place that sells screws, nuts and bolts etc.
Current bikes: 1960 Triumph 5ta x2, TTR600RE, KTM200EXC, Cagiva Elephant 900ie.
Jrod
Page 3 Girl
PostPosted: 13:48 - 28 Jul 2005    Post subject: Reply with quote
No they are still on the bike. He's trying to de-restrict it. Tut Tut
Reevo8
PostPosted: 14:56 - 28 Jul 2005    Post subject: Reply with quote
Dont be fucking silly, how stupid do you think I am?
Cheeky beggar.
Guest
PostPosted: 15:51 - 28 Jul 2005    Post subject: Reply with quote
Use a flat-ended piece of bar or a drift and gently tap the ends over to 'fill' the cross-point hole up again with material. Then use an impact driver with the largest bit that will fit and give 'em a sharp tap.
PostPosted: 16:22 - 28 Jul 2005    Post subject: Reply with quote
And when you find that doesn't work, drill the heads off them and remove the stump with a pair of pliers.
They probably burred them off on purpose to stop you doing exactly what you are doing.
If you even THINK about putting screws back in that you know have burred heads, I will personally track you down, come round your house and give you the kick up the arse you so richly deserve on general principle.
Get them out, throw them in the bin and fit new ones! Even if they are an obscure size, a genuine honda part will only cost pennies.
Guest
PostPosted: 23:49 - 28 Jul 2005    Post subject: Reply with quote
Derrrrr, never fort of that Embarassed Not used to this sort of thing you see. The only restrictors we had as a lad was the carb top vibrating off Laughing
Razz
The last post was made 21 years, 79 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 52.85 Kb
