| Kram |
 Kram World Chat Champion
| Trixie |
 Trixie World Chat Champion
 Posted: 11:46 - 29 Jul 2005 Post subject: |
As above.
However quite likely it is the plugs. Worth taking them out and having a look (which reminds me that I really must replace the plugs in my FZR). They are cheap and easy to replace anyway, but have a look at the condition.
Any idea which cylinders are not working? Put some water on them and see which ones take their time drying off as the exhaust warms up.
There are a few things it could be. Partially bunged up carb. Valve clearances (although on a shimmed engine they normally close up, and that normally results in more problems as they get warm). Carb dumping fuel down into one cylinder when parked. Could even be the first sign of the head gasket going.
Any other symptoms?
| Kram |
 Posted: 13:11 - 29 Jul 2005 Post subject: |
Cheap solution. Find the cylinder that is not firing when you start it. Then swap the plugs round and see if the problem moves.
Also see if the cylinder that is not firing is the one that had the exhaust missing, although I would not expect that to affect the plug much (not sure what it would do to the mixture on that cylinder, but a very lean mix is probably more likely to damage the exhaust valves).
| Kram |
| Kram |
 Posted: 15:11 - 29 Jul 2005 Post subject: |
just added new plugs.... after i found 4. bought 3 from halfords. went to 4 other places couldn't find any plugs. so i improvised...
works a treat now now to afford a new clutch  ____________________ FS1E -> SR125 -> CB400N -> CB650 -> FZR600 Genises -> VFR400 NC21 -> CBR900RR Fireblade -> Renault Clio 1.4 |
 Posted: 19:09 - 29 Jul 2005 Post subject: |
| Kram |
 Posted: 21:37 - 29 Jul 2005 Post subject: |
Plates are about £40. Tools required are an allen key set and a 10mm socket. About half the job is taking the fairing panel off and putting it on again, then a bit of fiddling with the adjuster on the sprocket cover. It might take you a couple of hours, but probably under an hour for an experienced professional.
Brief description.
Take the r/h fairing panel off, take off the clutch cover (about a dozen allen key bolts) and marvel at the clutch you find. Undo the 5 bolts holding the pressure plate on (each has a spring under it) and take the plate off. Then slide the plates out.
Put the new friction plates in (it will alternate one friction plate and one steel plate), put the pressure plate back on (not there is normally a mark to show which position it goes back in) and put the bolts and spring back in and tighten them up.
The oil level is low enough that on the side stand little / no oil will come out.
Note that the new plates should be soaked in oil for a while before installation.
| Kram |
 Posted: 22:01 - 29 Jul 2005 Post subject: |
No particular order with standard stuff, just alternating between a steel plate and a friction plate (think there is one more friction plate than steel plate).
The cable is easy to adjust, once the l/h fairing panel is off (just to get clearance for a screw driver). Take off the rubber cap from the actuating mechanism on the sprocket cover. Slacken off the lock nut. Then (from memory) tighten the adjuster to take up all the free play then back it off 1/4 of a turn and tighten the lock nut.
| Kram |
| Kram |
| Kram |
The last post was made 21 years, 116 days ago. Instead of replying here, would creating a new thread be more useful? |
