bike problems
benc
PostPosted: 13:12 - 31 Jul 2005    Post subject: bike problems Reply with quote
on my zxr400 it wont rev above 2k even at full throttle with the air box on, once i take it off it will run ok any idea what this could be? maybe running too rich?
TOM M
PostPosted: 22:06 - 31 Jul 2005    Post subject: Reply with quote
maybe there is a blockage somewhere???
Now owner of a 1200 Bandit
Jrod
Page 3 Girl
PostPosted: 11:01 - 01 Aug 2005    Post subject: Reply with quote
Dunno, sounds f*cked.
Trixie
PostPosted: 12:10 - 01 Aug 2005    Post subject: Reply with quote
Check yer carbs. Jet size, needle setting, etc.
Dead nobodies in company cars...
stu_m
PostPosted: 18:12 - 01 Aug 2005    Post subject: Reply with quote
checked the air filter ?
the grim reaper
PostPosted: 12:56 - 02 Aug 2005    Post subject: Reply with quote
I'd check the carb slides aren't stuck (assuming the air filter is clean), get the carbs balanced and cleaned and also check that the jets aren't too big. If the bike revs well with the airbox off (when the airflow is less restricted) then it sounds like you are running rich with the airbox on.
Grim
map
Mr Calendar
PostPosted: 13:47 - 02 Aug 2005    Post subject: Reply with quote
Agree with above to check carbs, etc.
However, as a quickie can you see if the airbox isn't simply fouling your throttle line and/or fuel? Possibly it isn't anything close, but I've seen bikes stripped down for less Wink
The last post was made 21 years, 112 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 50.54 Kb
