Tyres (yet again) - X-Ply to Radial switch?
map
Mr Calendar
PostPosted: 14:13 - 03 Aug 2005    Post subject: Tyres (yet again) - X-Ply to Radial switch? Reply with quote
Just noticed that my bike original spec is for X-ply tyres and that's what appears to be fitted. However, I've heard good things about the radial alternatives.
So is there any safety or handling issues in fitting radials if the original spec says x-ply?
Any advice welcome. Thanks Thumbs Up
PostPosted: 14:52 - 03 Aug 2005    Post subject: Reply with quote
Not much, but check you really can get appropriate size radials, and avoid mixing them (and a radial front with a cross ply rear is illegal).
iCraig
PostPosted: 15:48 - 03 Aug 2005    Post subject: Reply with quote
Map, what bike is it?
Also my take on things is if it ain't broke don't fix it, also bike manufacturers spend millions on bike design and use the tyres they think are suitable for the job in hand.
I personally see no benefit over Radials to Cross Ply's other than the extra cost that Radial tyres normally carry with them and the slightly wider tyre choice, but dependant on the bike this maybe miniscule.
map
Mr Calendar
PostPosted: 16:05 - 03 Aug 2005    Post subject: Reply with quote
Craig- wrote:
...no benefit over Radials to Cross Ply's other than the extra cost that Radial tyres normally carry...
The radials would actually save me about £30 on the pair Shocked
Cost isn't the only consideration, I'd prefer just to have the choice.
Craig- wrote:
...bike manufacturers spend millions on bike design...
Then Johnny Power-Ranger comes along with his aftermarket can and all the tarty bits Wink
PostPosted: 16:14 - 03 Aug 2005    Post subject: Reply with quote
Radials also tend to last longer for the same level of grip.
TOM M
PostPosted: 16:43 - 03 Aug 2005    Post subject: Reply with quote
whats the difference between the two?
Now owner of a 1200 Bandit
map
Mr Calendar
PostPosted: 16:54 - 03 Aug 2005    Post subject: Reply with quote
It's the way the tyre is built up with different layers.
Radial goes around and crossply or bias goes across.
Each offers advantages and disadvantages in terms of performance, strength and wear.
You can tell the type from the code. Radials will have R (or ZR) before the rim size. Xply will have nothing or a dash (and Bias may have a B).
e.g. 110/70 R17 is a radial where as 110/70 -17 is xply.
The last post was made 21 years, 108 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 56.61 Kb
