Tyre pressures
MikeyC
PostPosted: 10:50 - 04 Aug 2005    Post subject: Tyre pressures Reply with quote
Havent checked mine for a long, long time... Embarassed
Need to check them tonight, what psi should they be reading? I never carry a pillion if that makes a difference.
bilbo
PostPosted: 10:56 - 04 Aug 2005    Post subject: Reply with quote
It all depends on your tyre and the weight of your bike and load your carrying.
It should say the maximum inflation pressure on the side of your tyre.
Burn rubber not your soul!
MikeyC
PostPosted: 11:13 - 04 Aug 2005    Post subject: Reply with quote
Would probably help if I actually took a look Wink
Walloper
PostPosted: 11:24 - 04 Aug 2005    Post subject: Reply with quote
mikec106,
Halfrauds digital Pressure guage accurate and bullet proof.
Had mine under the seat of three bikes. Small enuf to fit on the valves of stupidly designed rims too. About £5.00.
($10.00 to our US cousins who are reading this.)
Within 3psi of tyre manufactures spec for bike/tyre will be OK but up to your individual taste and riding style, if you have 'style'.
I ran with 5psi in a T/cat for two days (so did my bro.) never thought to check the pressures.
It was a bit lumpy on fast bends. I must have looked like Rossi sliding the back end in. But not as handsome some might say.
I had a puncture but 'Slimed' it and ran it to destruction.
Scottish thrift we call it.
Hope this helps.
Kram
PostPosted: 11:37 - 04 Aug 2005    Post subject: Reply with quote
i gotta check my tyre pressures. i run what pressures are in my haynes (36F, 42R)
FS1E -> SR125 -> CB400N -> CB650 -> FZR600 Genises -> VFR400 NC21 -> CBR900RR Fireblade -> Renault Clio 1.4
PostPosted: 11:48 - 04 Aug 2005    Post subject: Reply with quote
The correct tyre pressures should be a lot lower than the max on the tyres.
MikeyC
PostPosted: 13:14 - 04 Aug 2005    Post subject: Reply with quote
What noticeable difference will there be if the pressure is lower than it should be?
The gixxer is my first 'big' bike, so everything is still a learning process for me.
Walloper
PostPosted: 13:31 - 04 Aug 2005    Post subject: Reply with quote
Cornering stability and possible damage to side wall if tyre pressures are too low/high.
Too high causes O/heating.
Why for 'track days' you can drop the standard 2-3psi to warm up the tyres faster. But you are constantly on the limit so pressure gets up to normal.
Too high a pressure pushes the centre of the tread onto the road and produces a narrower 'footprint' less grip.
Tyres pressure are supposed to be set when tyres are cold.
I've never tried setting cold riding till warm and checking.
It is better to do it cold as compressed air used to inflate will be cold and would upset a warm tyre.
The manufactures have been dicking with tyres for years so do know best.
The 'Sages' of this forum will know doubt know better than me of course.
Also try and use Nitrogen to fill your tyres as it is clean and has no moisture content. If you need to be picky.
Walloper
PostPosted: 13:35 - 04 Aug 2005    Post subject: Reply with quote
I am a W4nker. Too LOW pressure will cause O/heating.
Sorry for the fu(k up.
Hope you didn't adjust to suit.
MikeyC
PostPosted: 13:50 - 04 Aug 2005    Post subject: Reply with quote
Not gonna do anything til after work, but thanks for the advice Thumbs Up
Chriss
PostPosted: 13:57 - 04 Aug 2005    Post subject: Reply with quote
I ride a Triumph Daytona 600, and I run 32 front and 34 rear. My dealer set my tyres to 42 front, and 44 rear (was bloody scarey). Hope that might be of some help.
TheShaggyDA: I've got 3 or 4 pairs that predate my wife, so at least 11.5 years old.
mchaggis
PostPosted: 14:00 - 04 Aug 2005    Post subject: Reply with quote
You can usually tell if they are too low because the bike will often feel slithery and uncertain. It is more pronounced on a slimey/ wet road.
I must not be a troll...
Mmmm, Guinness
PostPosted: 14:01 - 04 Aug 2005    Post subject: Reply with quote
G can probably say more (more experience playing with the pressures), but a higher tyre pressure will result in a more skittish feel. Lower pressures will result in more movement in the tyre and feeling less stable. On the front a tendency to try and turn in as you are cornering.
MikeyC
PostPosted: 14:21 - 04 Aug 2005    Post subject: Reply with quote
Just a case of finding the right balance then I guess!
Wave2k
G's Stalker
PostPosted: 14:23 - 04 Aug 2005    Post subject: Reply with quote
having a low tyre pressure dramatically changes the handling of the bike
i didnt check mine for ages
i had 15 PSI in the front and 25 in the rear
pumped them both up and it handled like a dream
Ducati 1299 Panigale
2009 Corvette C6 z51
MarkyPancake
PostPosted: 11:50 - 05 Aug 2005    Post subject: Reply with quote
I was running my R1 by the book, 36 front and 42 rear as it still has factory Dunlops on, and then someone advised me that I should be running them slightly lower and pointed me in the direction of Dunlop Tyres' UK web site which has a fitment/pressure guide and advises to run 36 front and 36 rear solo psi.
https://www.dunloptyres.co.uk/bike/
The last post was made 21 years, 108 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 88.77 Kb
