Torque Wrench
Gracie Jones
PostPosted: 15:22 - 04 Aug 2005    Post subject: Torque Wrench Reply with quote
Hey there,
Can anybody tell me what the measurement 1 / 2 or 3/8 actually refers to on a torque wrench?
I want to buy one that will be good for things like removing wheels and removing the oil nut, so a broad range of nm would be good.
I've seen a 1 / 2 one for 20-200nm, but previously I was advised to get a 3/8 one, which presumably is smaller. But would a smaller one be big enough to do big stuff like removing rear wheel?
Any advice appreciated!!
Best wishes to all,
Luke
mchaggis
PostPosted: 15:35 - 04 Aug 2005    Post subject: Reply with quote
It is the size of the drive 'peg' in inches. A 3/8" drive should suit most things, you can then get adapters to fit 1/4" and 1/2" drive sockets. A quality tool should have small enough tolerances that doing up a 20mm socket with a 3/8" drive shouldn't be a problem. You can always use an extender bar if you're worried about lack of leverage.
To remove nuts, you just use an ordinary socket wrench/ ring/ C spanner, depending on access.
I must not be a troll...
Mmmm, Guinness
Gracie Jones
PostPosted: 16:25 - 04 Aug 2005    Post subject: Reply with quote
Cheers McChaggis, a 3/8 it is then.
Many thanks.
PostPosted: 17:02 - 04 Aug 2005    Post subject: Reply with quote
Check the official torque figures for the bolts you are likely to use it on. My 3/8" drive one goes from 5lb/ft to 40, so useless for doing up the head bolts on the car (65lb/ft), yet the larger 1/2" drive one does not read low enough for the head bolts on the 125 2 stroke engines (14~18lb/ft).
The last post was made 21 years, 110 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.34 - MySQL Queries: 13 - Page Size: 39.92 Kb
